Andersen Ultimate hitch help
Old Mar 4, 2018 | 11:10 AM
GT4point6's Avatar
GT4point6
As simple as it is, I'm having a issue.
Ultimate Hitch II with a Curt gooseneck ball made for Ford OEM puck system as seen here.
Ultimate 2
Curt Gooseneck ball for Ford OEM
Problem is, when I tighten the top bolt down, it bottoms out in the frame and doesn't put any tension on the ball. I can still spin the hitch and it has about 1/4" play up and down.
Side bolts are loose, I confirmed that the inner housing is bottoming out in the main housing so it will not come up anymore.
Is the Curt gooseneck ball too tall? That is what it seems like but thought they would all be the same as I did not see any advertised as "short", "regular", or "tall".
Old Mar 4, 2018 | 11:22 AM
GT4point6's Avatar
GT4point6
I think I figured it out, the Curt ball for the Ram is lower, the one for all the other makes (Ford, Chevy, Nissan, etc...) is the taller version and too tall.
Ordered the lower version for the Ram, hopefully it fits....
You can see both on this page,
Curt Gooseneck *****
Old Mar 4, 2018 | 02:06 PM
HRTKD's Avatar
HRTKD
I'm interested to see how this is resolved. I have the Curt gooseneck ball also.
Old Mar 4, 2018 | 02:44 PM
SkiSmuggs's Avatar
SkiSmuggs
Andersen is very helpful for this kind of problem. I have heard of them sending a new connection box for the AUH.
Old Mar 10, 2018 | 06:20 AM
GT4point6's Avatar
GT4point6
Got the new Curt ball, https://www.curtmfg.com/part/60601 Don't ask me why they think the taller one is for Ford/Chevy/Nissan and the shorter (standard size) is only for Dodge.
The Dodge ball works great with the Andersen hitch and has same profile as most others you see out there. The taller ball probably wouldn't be a problem with a true gooseneck.
Old Mar 15, 2018 | 07:54 AM
dksmith17's Avatar
dksmith17
So is the Curt Dodge the ideal ball setup for the Andersen hitch?
I see some recommend Reese turnover ball and also the pullrite ball for solving the safety chain problem
FWIW I'm purchasing a preowned (unused) Andersen Ultimate today.... and there was mention of it including a ball + chains. This to match with a F250 F2018(not here yet) and a Jayco 26.5BHS
Old Mar 25, 2018 | 07:37 AM
USSenator's Avatar
USSenator
I had the same issue with my Curt Gooseball. I called Andersen and they sent me a shorter tube. It fits snug now. I towed ~1,500 miles with the loose hitch.
Old Mar 27, 2018 | 08:56 PM
SkiSmuggs's Avatar
SkiSmuggs
FYI, the Reese goose ball is fine with the AUH.
62vetteman
Feb 13, 2017 07:38 PM
Twilight Fenrir
All Things Towing
22
Oct 25, 2013 05:11 PM
harris25
6.7L Power Stroke Diesel
Aug 6, 2011 04:55 PM
Big tmiller
All Things Towing
Nov 19, 2007 12:48 PM
rebocardo
All Things Towing
Oct 15, 2004 12:07 PM
