Long time listener, first time caller.
Is there a gooseneck ball extender available for the factory gooseneck hitch, which I understand is a Reese Elite system? Figure if anyone knows they will be here. TIA
Rob
Rob
The ball in the Reese Elite we installed in the school's Silverado 2500HD does not rotate when installed. The ball shaft has two ball bearings opposite each other that lock into indentations in the tube.
The issue is not with the ball rotating it's with how it is secured and released. Currently nobody is making an adapter that connects into the ball mount and pushes the ball 4" to the rear. I changed my order and simply purchase a B&W.
