Sponsored by: Real Truck
Factory hub question
Old Mar 4, 2018 | 10:11 AM
Mikec35's Avatar
Mikec35
My 2001 has what appears to be factory hubs. I had trouble the other day when trying to back up a small wet grassy hill, only one rear wheel was spinning in 4wd high with the hubs in Auto mode. I pulled the truck a few feet forward and got out and locked my automatic hubs in manually and the truck climbed the hill. One thing I noticed when locking the hubs in manually was that one hub had a little resistance turning from auto to manual while the other hub was real easy to turn. Per a receipt given to me by the previous owner who had what he said was $2500 worth of front end work the following items were installed at a Diesel service shop about 1000 miles ago: axle seals, axle tube seals, hub seals, wheel bearing o-rings and 4' of vacuum line, plus some obvious front end suspension components. How can I check this 4wd system out to make sure it's working correctly in both Auto and manual mode - put the whole thing on jack stands and run it through the motions or is there other things I should be looking for? Thanks
Old Mar 4, 2018 | 05:38 PM
00t444e's Avatar
00t444e
Sounds like you have a vacuum leak that's not letting the hubs engage when in auto.
kameronth
Feb 11, 2013 04:58 PM
mgraveman
Mar 19, 2010 07:15 PM
Sakison
Feb 10, 2010 08:11 AM
jlstorm
Dec 29, 2008 11:33 AM
BigRyanKP
Nov 7, 2003 06:54 PM
