Another front hub question
Old Mar 18, 2010 | 07:59 AM
mgraveman's Avatar
mgraveman
I have an 01 with 4x4 and factory hubs. One hub is very difficult to turn, and using a wrench on it it became cracked. I didn't realize they were auto hubs at the time. I have since discovered they are auto hubs, but when I give it much gas it will disengage and reengage under load (very bad). I am wondering if this could be related to the crack in the front - is that what holds the vacuum in?
Can I just get this part of it and not replace the whole hub?
Old Mar 18, 2010 | 10:08 AM
SkySkiJason's Avatar
SkySkiJason
Welcome to guzzle's 4x4 Autolock Hub Lubrication Maintenance Web Page
This should help. Many ditch the auto hubs and replace with WARN or similar hubs. I like the auto's myself...
Chances are your hub is not fully engaging/disengaging (frozen). Try spinning axleshaft to see if its locked or grinding (partially locked). When mine were 'sticky' last time, I'd have to unlock them manually while tapping on them to get'em to unlock. The cracked/broken plastic shouldn't affect manual operation.
Let us know how ya make out!
Old Mar 18, 2010 | 10:12 AM
mgraveman's Avatar
mgraveman
Thanks!!
Do you think I can get the plastic front without replacing the whole hub?
Old Mar 18, 2010 | 03:11 PM
SkySkiJason
Originally Posted by mgraveman
Thanks!!
I dunno???
Old Mar 18, 2010 | 10:00 PM
EXv10's Avatar
EXv10
Thanks!!
I doubt it unless you could get a whole shot hub, better yet, get a whole good hub.........should be a lot around. Next time drill a hole in the dial and set it in a bowl with ATF overnight.
Old Mar 19, 2010 | 08:39 AM
chazman's Avatar
chazman
Can you pinpoint where to drill the hole in the dial?
Old Mar 19, 2010 | 07:15 PM
EXv10's Avatar
EXv10
In the recessed part, just so oil will drain in there. A little hole and you can put a screw in it later. Let us know how it worked.
