2007 Explorer transmissions codes
Old Mar 4, 2018 | 02:30 AM
khadma's Avatar
khadma
Carpenter Local 745
The truck has about 100,000 miles.
Issue started today. Drivability and I suspect the truck was driven 8 miles home in limp mode by my wife.
P0750 solenoid A
P0755 " B
P0760 " C
P0765 " D
Are all of these located on/in the solenoid pack?
I know the truck was due for a fluid change, and I sure hope there are not a lot of metal shavings in the pan/transmission.
I just need to see if anyone has repaired these DTCs.
Old Mar 4, 2018 | 08:13 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
When all the solenoids set electrical codes 999 times out of a thousand the problem is in the wiring harness, not the solenoids. Changing the solenoids is almost certainly not going to fix this.
Old Mar 4, 2018 | 10:11 PM
jk080's Avatar
jk080
Transmission Rebuilder
If this vehicle has the 5R55S transmission in it you should look at the case connector, water from the AC drain drips down on the connection and causes them to corrode. I have had to replace the solenoid block and pigtail wire harness on several of these.
If it has the 6R60 transmission in it there is a possibility the lead frame connector inside on the valve body may have a problem, I usually see speed sensor codes for this one but I have read of solenoid issues here too.
Make sure the connector on either one is tight and secure.
Old Mar 22, 2018 | 02:50 AM
khadma's Avatar
khadma
Carpenter Local 745
Truck went back in after issues could not be replicated. Truck started acting up for the technician to see in person. He told my wife there could be a valve issue since the truck had trouble shifting into reverse and sometimes drive.
We were told it could be a $4000.00 repair. The truck is worth 6000.00 at best, my wife wants to repair the transmission for now.
THEEwhiteboy
1997 - 2003 F150
Feb 27, 2019 09:22 PM
Nelson Arivett
1997 - 2003 F150
Mar 10, 2017 06:33 PM
UGA33
Feb 17, 2017 10:09 PM
Hq254xp
Jun 3, 2016 06:42 PM
96_F250_Deezal
Sep 13, 2013 10:21 PM
