Bed mat
Old Mar 6, 2018 | 05:56 PM
  #31
Bill_The_PA's Avatar
Bill_The_PA
Originally Posted by MDK123
What visors you going with? I broke two pairs of weathertechs so I’m looking for the next best thing. The in-channels broke when I rolled up the fronts. Backs were fine ...
My F150 had the In channel WT as well. Junk. they scratch your glass if you get just a little grit on your glass.
Ive hag great luck with Stampede products.
Old Mar 6, 2018 | 06:08 PM
  #32
Bill_The_PA
To the OP.
Depending on your needs would direct my recommendation. I’ve had the hard rubber OEM and their heavier then most but also are bulletproof. I’ve had custom fit carpet by action trucks and wow very light, comfortable under foot, hand, and knees but it’s carpet so your giving it heavy protection capacity. So it depends on how you use your rig. If it’s alrea spray lined then I’d recommend carpet it’s just so easy to move and clean but if you don’t use a tonneau cover you’ll likely find it blowing out of the box lol.
Old Mar 6, 2018 | 06:29 PM
  #33
wrvond's Avatar
wrvond
Originally Posted by Dan1954
Be sure any bed mat you order is heavy enough to it doesn't move around in the bed. I ordered a Ford mat which is heavy and have had no problem. I ordered an aftermarket mat to use with the gooseball & my Anderson Ultimate hitch. I didn't want a hole in my bed mat when I am hauling leaves, etc so I am using the aftermarket mat when we pull the 5th wheel only. Well the aftermarket mat is lighter, & the 5th wheel when traveling at 65 mph or so seems to create a down draft which causes the back edge of the mat to flap up & down which then eventually knocks the electrical connection loose, leaving me without lights, which can be a problem if your in an area where you can't easily pull over every 5 miles to fix it & you have nothing with you to weight the mat down.
A 2x6 cut to 66.5" long will solve that problem.
Old Mar 6, 2018 | 06:33 PM
  #34
cficare's Avatar
cficare
Wink
Yeah, but if he's towing a 5er, why would he use the WD bars like you have?
Old Mar 6, 2018 | 06:41 PM
  #35
wrvond's Avatar
wrvond
Edit:
Just saw the wink...
The real magic is in the orange milk crate. Not only does it hold the board in, the bed mat down, and the wood chunks in one place, it serves as a step so I can reach the 5th wheel hitch, too!
Old Mar 6, 2018 | 06:56 PM
  #36
Bill_The_PA
wonder Y the WD hitch is even there? Are the ford claims not accurate? You actually need a WD hitch?
Old Mar 6, 2018 | 07:07 PM
  #37
wrvond's Avatar
wrvond
I've never actually seen anything in writing from Ford that says weight distribution is not needed. Most people focus on the fact that a WDH moves weight from the drive axle to the steer axle, which is true enough. However, a WDH also moves weight onto the axle(s) of the travel trailer. This is very important - especially when towing empty campers to dealerships.
I've also been told, though I don't know this from personal experience, that weight distribution bars will prevent a TT from blowing over in high wind situations. I can see where it would help, but I'm not completely convinced they would actually stop one from rolling over.
Old Mar 6, 2018 | 07:23 PM
  #38
Bill_The_PA
well to be honest I haven’t read that either. Just assuming as all the videos I’ve seen (including ford reps stating this as well, but not a Ford video was TFL video) state with the 24x stiffer frame and improved suspension that no WDH required. As far as the wind. I’ve never experienced a blow over but my Dad has. He said even if the trailer was welded to the truck that sail (Long 5er) was turning him an his side. But I’m no expert on WDH. IMHO it can’t hurt right
Old Mar 6, 2018 | 08:11 PM
  #39
wrvond's Avatar
wrvond
The first part of February I did have a TT blow over in Wyoming. I wasn't using the WDH at the time and Safety/Compliance informed me the WDH would have prevented it. As I said, I'm not entirely convinced, but I use it religiously now. In the same windstorm another driver was pulling a 5er and it blew over as well. I'm lucky, mine popped off the ball and put a small scratch/dent in my tailgate, his ripped his fifth wheel hitch out of the truck. I didn't see the truck, but the hitch was a twisted up mess. I can only imagine what it did to his truck.
Old Mar 6, 2018 | 09:08 PM
  #40
FONRDAY's Avatar
FONRDAY
yeah
Threw the ford embossed mat in my bed yesterday. Love it.
I have it. things stay on it all with out rolling around.
Old Mar 6, 2018 | 10:03 PM
  #41
Bill_The_PA
you raise an excellent point the Ford OEM Mats sure was work well as anti slip. Totally worth mentioning again
Old Mar 6, 2018 | 10:20 PM
  #42
FONRDAY's Avatar
FONRDAY
yababadoooo
yeah anti slip again
Old Mar 9, 2018 | 04:41 PM
  #43
Larrymac52's Avatar
Larrymac52
In the Ford specs it had the width of the bed at the floor as 66.9”?
Old Mar 9, 2018 | 07:18 PM
  #44
cficare's Avatar
cficare
Measure twice, cut once. The Ford specs also said my 2017 F250 was 81-1/2"high, but it measured 83" high. There are all sorts of tolerances allowed in automated sheet metal assembly. I recall another vehicle where a prominant repairman documented 2" of difference in the size of the engine bay across many of his customers' cars. Why would a cargo bed be any different?
Old Mar 9, 2018 | 07:59 PM
  #45
Bill_The_PA
good point. That’s Y the last time I made a 2x divider I templated a left and right 45” pieces once contouring was done I clamped the two pieces for a perfect fit. So I don’t even measure.
