Sponsored by: Auxito
coil pack
Old Mar 2, 2018 | 01:10 PM
ford hateing sob's Avatar
ford hateing sob
coil pack
I have a 97 4.6 f150 I changed all the wires and plugs took care of the miss for a while and started missing again. I cleaned all the plug holes very good the second time and replaced plug that showed miss fire this has been going on for some time now for the fifth time miss on 6 egr code replaced plug egr and actuator it ran 19 miles perfect and started again. My question is will a coil pack gradually break down or when it is bad it is bad. I have thought about moisture and hair line cracks this thing is driving me crazy any advice?
Old Mar 2, 2018 | 01:14 PM
Chad T. Keogh's Avatar
Chad T. Keogh
I had #3 coil fail on my 1999 F-150 at 200,000 miles (320,000kms approx). Replaced them all with Accel coils. No problems since.
Old Mar 2, 2018 | 01:40 PM
ford hateing sob
Mine has the two coil packs on the front of motor not in the wires. Have you ever heard of a gradual breakdown of a coil pack
Old Mar 2, 2018 | 02:07 PM
Chad T. Keogh
Old Mar 3, 2018 | 08:24 AM
ford hateing sob
I have gone through all the cleaning out of the holes and everything is dry 4 times no moisture I guess I will try a new coil pack last resort. Its got me stumped
Old Mar 3, 2018 | 08:29 AM
Steven@nd's Avatar
Steven@nd
Yes, the coil packs on my T-bird 4.6 failed and started cross-firing between the wires.
Old Mar 3, 2018 | 03:18 PM
ford hateing sob
Well changed coil packs still doing same thing runs perfect until it warms up and starts missing
Old Mar 3, 2018 | 03:40 PM
Chad T. Keogh
That sucks. Might have to bite-the-bullet and bring it to the nearest Ford dealer for a diagnosis. Could save you time and money in the long run.
Old Mar 3, 2018 | 04:06 PM
Bluegrass 7's Avatar
Bluegrass 7
What codes are being set?
Old Mar 3, 2018 | 04:43 PM
ford hateing sob
I recon so. I guess its no time to worry about money now I have so much in it WTH. Ford has always been known for over engineering my luck it will be a 30 dollar relay or something like that.
Old Mar 7, 2018 | 12:30 PM
ford hateing sob
Well the problem all along was clogged EGR ports, I got close when I replaced the EGR I cleaned as much as I could see but I didn't look far enough. Lesson learned
Old Mar 7, 2018 | 02:53 PM
steve(ill)'s Avatar
steve(ill)
like Bluegrass said.............. what was the code ? If you took it to the dealer, SOMETHING told them to look at the EGR and not the coil.
Old Mar 7, 2018 | 03:27 PM
Bluegrass 7
Sorry to say this but "blocked" EGR ports won't cause a miss on V8 motors.
You just happened to find the blockage. Otherwise a code 401 would have been set if you had checked. The computer self diagnostics checks the EGR system for a number of functions 2 times on every drive cycle..
If the missing is really clear, you unknowingly did something else while working on the EGR system.
Explanation:
The EGR does not open until either in OD above 45 mph or in manual third gear with OD switched off:
This mean with a blockage it could not make a difference in anything but a reduction in fuel mileage and the CEL would be on with a supporting code set.
I think your against the truck because you don't understand that the complex systems have to be understood so codes are set to help with the trouble shooting.
All modern vehicles of the last 25 years are the same way. Buy another make and you have the same level of complication. Trucks after 2004 at even more complex.
Good luck to you.
bcompton35603
Dec 10, 2009 02:31 PM
DoofusOfTheDay
1997 - 2003 F150
Feb 8, 2008 10:44 AM
PSUJTF76
Mar 26, 2007 12:25 PM
mitchymitch
1997 - 2003 F150
29
Mar 11, 2004 07:15 PM
