1978 - 1996 Big Bronco
Help
Old Mar 2, 2018 | 01:01 PM
86bronc's Avatar
86bronc
Help
I've been 1986 Bronco in 2010 we put in 91 302 since then been having issues with it running rough not starting when it's cold stalling and a host of other issues it's been in and out of the garage for the last 2 years and we haven't completely figured out the problem I was told it has a cam from a 351 but I thought they were interchangeable the 302 is an ho motor and has electronic fuel injection when I change the motor to the 91 we didn't change the ECM could this be the problem or is it the wrong camshaft we've changed every sensor distributor harmonic balancer wires plugs no change would an aftermarket computer setup solve my problems or does anyone have a solution
Old Mar 7, 2018 | 10:11 AM
rla2005's Avatar
rla2005
Did you route the spark plug wires for the HO/351 firing order or retain the original firing order?
bootie
May 13, 2005 06:28 AM
krazycrx
Engine Swaps
Oct 24, 2004 01:32 PM
lurch
Dec 29, 2003 09:35 PM
ClatonK
Nov 10, 2003 12:25 AM
Franklin2
Sep 27, 2001 12:42 PM
