Injector low voltage
Old Mar 1, 2018 | 01:57 PM
johnsonjf's Avatar
johnsonjf
im getting a low voltage code on injector #7 but only when pulling a load of about 10K lbs. I have not had one with a lighter load say 4K lbs. is this a sign the injector is failing? The IRP shows 23.4-23.8 under normal idle but when I get this code it goes up to 26.3-26.8. The truck doesn’t run bad when this happens, just annoying.
Thanks,
Jeff
Old Mar 1, 2018 | 03:22 PM
navistarnut's Avatar
navistarnut
Double check the connections on that injector and the FICM
It might also be a sign of something in the FICM that happens randomly.
What kind of FICM readings are you getting?
Main, V's and logic?
Old Mar 1, 2018 | 03:47 PM
johnsonjf's Avatar
johnsonjf
I didn’t check the FICM readings during the code so I’ll have to wait for the next time it shows up and see what it shows.
Thanks,
jeff
Old Mar 1, 2018 | 06:25 PM
mattdoc88's Avatar
mattdoc88
If you have torque pro, log your drives in case it happens, then you'll know you have data saved and not have to try to catch it in the act.
Royson12
Oct 21, 2017 07:46 AM
elyrain
Jan 10, 2015 05:40 PM
fire446
Oct 31, 2013 06:32 PM
qdrider01
Dec 8, 2009 08:17 PM
DAG/PA
Nov 22, 2007 04:24 PM
