E rated tires
Old Feb 28, 2018 | 11:10 PM
1911fan's Avatar
1911fan
E rated tires
Anyone else using 65psi load range e tires on their truck to pull a 5th wheel instead of the 80 psi? I ask because i forgot to look when i got new tires the other day and now this is what im stuck with. Any issues with blowing out or shifting belts? Im still within the weight limit but now only by 700lbs instead of 1500lbs.
Old Mar 1, 2018 | 08:27 AM
WE3ZS's Avatar
WE3ZS
What size are those 65 PSI tires? My Load Range E Nitto Duras are 65 PSI max tires but they are also much larger than my stock 80 PSI tires were. Mine are 305/70R18 (35X12.8) and so far with 22K towing miles (and a few more running solo) they are holding up and wearing very well. I tow a bumper pull TT, but it's a very big one (41') with a very heavy tongue (1860lbs) and our traveling rear axle weight runs 6200/6650 depending on the trucks load for the trip.
Old Mar 1, 2018 | 09:23 AM
1911fan's Avatar
1911fan
Thank you thats helpful. Mine are 35x12.50r20. Mickey Thompson deegen 38
Old Mar 1, 2018 | 09:56 AM
WE3ZS's Avatar
WE3ZS
Yep, bigger tire = bigger footprint/ contact patch. So less air pressure needed to support the (same-ish) load.
Old Mar 1, 2018 | 10:25 AM
1911fan's Avatar
1911fan
Except they are rated 400lbs lower per tire than the stock tires
Old Mar 1, 2018 | 11:03 AM
WE3ZS's Avatar
WE3ZS
It varies by the tire design, mine were a decent upgrade in load rating compared to my stockers.
Old Mar 2, 2018 | 05:51 AM
Slowpoke Slim's Avatar
Slowpoke Slim
You must have a very light 5th wheel, with a light pin weight. Have you weighed your rig on a scale, to get a true weight, loaded and wet, and packed up to go camping? Hopefully you're not going off of the advertised "pin weight" that the manufacturer lists as unloaded weight. You could be in for a nasty surprise.
Old Mar 2, 2018 | 11:08 AM
1911fan's Avatar
1911fan
Ive weighed it. It is an ultra light 5th wheel. 34ft 9900 gvw. I cant tell you the actual pin weight because i didnt pull it off and re weigh but rear truck axle weight is 5700lbs and that was with an extra passenger that normally doest come with. And it was on the maiden voyage of that camper so all of the stuff was just pilled up by the door and not put away yet. I am planning to weigh again next time i head out in that direction.
Old Mar 3, 2018 | 06:00 AM
Chuck's First Ford's Avatar
Chuck's First Ford
weighting is a trustworthy way..
full rig and trailer....weight.. pull around back.. disconnect trailer.. re-weight truck..
Cat only charge one charge if both weights are within 24 hours...
my bumper trailer is 800 pounds more then both factory tags...
and I weighted it on the way home from the dealer I purchased it from,,, so it was truly empty.
and at 2 different cat scales... to make sure first scale was not wrong.
Old Mar 10, 2018 | 10:26 PM
951 DAN's Avatar
951 DAN
My dually came with E rated tires, 75 psi front and 65psi rear
Old Mar 22, 2018 | 03:21 AM
Beast2017's Avatar
Beast2017
I’m already shopping for my second set of tires I want to go with 35” or 37 looks like the metric size tires get a better rating. Looking for a mud tire that has the heaviest capacity as I feel like every upgrade to my truck should be an improvement.
1911fan
All Things Towing
Mar 3, 2018 09:51 AM
Silver04s
Feb 21, 2018 10:41 PM
DashingDaryl
Jun 28, 2007 12:34 PM
mjs90201
18
Sep 21, 2004 06:48 AM
Ultraute
Sep 9, 2004 08:30 AM
