The smoking wire
Old Feb 26, 2018 | 07:30 PM
gostephen's Avatar
gostephen
The smoking wire
I'm trying to get my truck road ready when it decided to start smoking from behind dash. I pulled dash panel and found this.
It was not connected to anything and what looks like a fuse holder was touching a ground
it only has power with key on
Anyone know what this connector is for?
I plan on breaking out the soldering iron out tomorrow and fixing this and some other questionable wireing before it becomes a problem
Old Feb 26, 2018 | 09:07 PM
mustangmatt's Avatar
mustangmatt
kind of looks like the plug for a factory radio, I could be wrong though.
Old Feb 27, 2018 | 12:00 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Matt believe you are correct factory radio plug. The inline fuse holder (white 1/2 part hanging out the bottom) I bet was a PO installed item. DAMN PO (Previous Owners). Did it get into any other wire bundles?
Old Feb 27, 2018 | 10:14 AM
meangreen92's Avatar
meangreen92
See if you can follow those wires back to where the discoloration ends, and determine the insulation colors. One of the wires should be light blue with a red stripe, and that powers the light in an OEM radio's dial. The other one should be yellow(?) and that is switched 12V+ from the "radio" fuse.
Alternately you could power up the truck (once you're sure you've separated the short) and probe those wires with a meter, and see if they conform to the characteristics I described.
Old Feb 27, 2018 | 11:25 AM
gostephen's Avatar
gostephen
The one that's not burned is light blue with red
Old Feb 27, 2018 | 11:28 AM
gostephen's Avatar
gostephen
I don't think it got any other wires fortuntly I was sitting in the cab working on some other stuff not driving and was able to kill power fast
and thanks for that image that will help me with some other minor issues
Old Feb 27, 2018 | 04:19 PM
gostephen's Avatar
gostephen
It is the radio connector
It melted the wire about 6 in to the main harness but miracles do happen it didn't melt any other wires
Old Feb 27, 2018 | 06:50 PM
HoustonDave's Avatar
HoustonDave
First basic rule of wiring: It stops working when you let the smoke out. Never let the smoke get out!
phurst
Jun 10, 2011 01:52 PM
WIKD
Sep 13, 2010 08:03 PM
haywoodya69
May 13, 2009 05:47 AM
splaq
Nov 7, 2005 08:55 AM
king_nothing351
Electrical Systems/Wiring
Dec 21, 2002 11:27 AM
