Engine Bore
Old Feb 25, 2018 | 05:34 PM
money pit 69's Avatar
money pit 69
Engine Bore
A couple of things. Will a stock head gasket set be OK when engine is bored .060. Should I get rid of the stock carb. spacer when installing new carb. EGR eliminated. THX David
Old Feb 25, 2018 | 06:07 PM
mrollings53's Avatar
mrollings53
What are you working on?
Old Feb 25, 2018 | 06:08 PM
money pit 69
1987 351w 4x4
Old Feb 25, 2018 | 06:35 PM
GoinBoarding's Avatar
GoinBoarding
You should be good with standard gaskets. Typical head gasket for a 351W has a 4.100" bore. Standard 351W bore is 4.000 so 0.060" overbore should be just fine with standard head gaskets.
Old Feb 25, 2018 | 06:47 PM
money pit 69
THX One more thing are Enginetech gaskets and parts OK?
Old Feb 25, 2018 | 08:13 PM
'89F2urd's Avatar
'89F2urd
I prefer using a gasket that is not so much larger than the bore itself, I'm honestly not sure why they go so large on them. Quench is better with a tighter gasket.
Pretty much any head gasket for a stock application is fine with proper prep and procedure (clean out bolt chases, block and head surface prep, bolt torque pattern, etc) but if you really want the best of the best buy a set of MLS gaskets and a quality set of bolts/studs.
Old Feb 25, 2018 | 08:22 PM
willowbilly3's Avatar
willowbilly3
You will probably need to keep a carb spacer so the linkage doesn't hit on the intake.
I've used nothing but FelPro for 30 years, never had a reason to swithch
Old Feb 25, 2018 | 08:39 PM
wtroger's Avatar
wtroger
I wouldn't bore any SBF to .060 over without a sonic test. I have seen to many bored that big that had problems overheating due to thin spots in the casting
Old Feb 25, 2018 | 08:53 PM
'89F2urd's Avatar
'89F2urd
Really? I've only seen some pretty robust blocks when it comes to sbfs, I've bored probably 3 dozen to 4.06 personally.
Old Feb 25, 2018 | 10:51 PM
wtroger's Avatar
wtroger
You are right. It is SBC you got to be really careful with. Getting old I guess.
Old Feb 26, 2018 | 05:39 AM
'89F2urd's Avatar
'89F2urd
I mean, it's never a bad idea to sonic check anything, I was genuinely curious if there were castings that were sub par so I could avoid them lol
Old Feb 26, 2018 | 07:41 AM
willowbilly3
And the 351c. Some of those blocks don't have enough meat on the thrust side at standard bore to build a performance engine, or so I've read. We've all dodged the bullet over the years but personally, I would sonic test anything that's getting bored .060, just for the peace of mind/
ben73058
59
Jul 24, 2020 07:17 PM
fluknick
16
Jun 10, 2012 11:45 PM
droach4u
Apr 25, 2004 12:25 PM
red75bronco
Mar 3, 2004 12:16 PM
