1994 F150 5.0L need p/ns for coolant temp sensors
Old 02-25-2018, 06:50 PM
oldhard47's Avatar
oldhard47
oldhard47 is offline
I have a 1994 F150 XL SC with 5.0L with manual transmission.
Contrary to seeming convention, I have 2 two-wire coolant temperature sensors.
Can someone give me the part numbers of both styles I have - the one on the standpipe near the base of the distributor and the other on the drivers side manifold near the front (which normally has the one-wire sender for the dash gage).
I've attached pics of both styles.
Old 02-26-2018, 08:55 AM
Scndsin's Avatar
Scndsin
Scndsin is offline
1st is ECT (coolant) that ECU uses for calculations, 2nd is ACT sensor (intake air temp).
You still have a 1 wire temp gauge for gauge.
Cheapest ECT @ O'Reily:
https://www.oreillyauto.com/detail/m...rd/f-150?q=ECT
Cheapest ACT @ O'Reily:
https://www.oreillyauto.com/detail/m...ntake+air+temp
Old 02-26-2018, 09:15 AM
willowbilly3's Avatar
willowbilly3
willowbilly3 is offline
Don't buy the cheapest ones. Go to your Ford dealer and get good ones.
Old 02-26-2018, 10:44 AM
Scndsin's Avatar
Scndsin
Scndsin is offline
Oh by all means get Motorcraft... if one can, but it ai'nt always available OR affordable.
Exercise was to show that parts are available & what he has ai'nt unique.
Old 02-26-2018, 10:50 AM
joey2fords's Avatar
joey2fords
joey2fords is offline
and rock auto has them both (motorcraft), so you are not at the mercy of a dealership.
Old 02-26-2018, 11:04 AM
Scndsin's Avatar
Scndsin
Scndsin is offline
I looked at rock first & they had zip in the sensors alone, so WTF?
At any rate he HAS 2 wire sensors & they are available.
Old 02-26-2018, 11:55 AM
willowbilly3
Old 02-26-2018, 02:55 PM
oldhard47's Avatar
oldhard47
Thank you for the info! I did locate the single wire gage temp sender - it was under a jumble of wires and a bit "south" of the ACT (which I think is also called IAT).
IMASAP
06-25-2015 09:59 PM
Ken_C
02-11-2013 08:01 AM
thdphd
Aerostar
04-17-2011 11:48 AM
danwink
01-23-2005 07:20 AM
Quick Reply: 1994 F150 5.0L need p/ns for coolant temp sensors
