Electrical issues
Old Feb 25, 2018 | 04:07 PM
snorindad's Avatar
snorindad
Electrical issues
So I have an issue with power to the window, radio, instrument cluster dome light, I believe that is all that is affected. Randomly i will lose power to these items, it will go off then back on until today. Unfortunately I have a window down and cant roll it up. Checked fuses and are good. I did have a viper alarm and remote start installed last July but this just started about four weeks ago. Any ideas? Thanks
Old Feb 25, 2018 | 04:12 PM
snorindad's Avatar
snorindad
Also truck starts and runs fine I have a cts and all numbers are good. Alarm and remote start work as they should.
Old Feb 25, 2018 | 04:48 PM
TooManyToys.'s Avatar
TooManyToys.
I'd first replace the fuse even if it looks good. Had you replaced the overhead lamps recently?
I'm not up on the later model trucks, but I though a few years back someone had similar issues and it was related to the gauge cluster. I may be whacked on that.
Old Feb 25, 2018 | 04:53 PM
navistarnut's Avatar
navistarnut
Pretty sure on later builds a lot of that stuff is controlled through the instrument cluster.
Yours does not have the GEM module like mine does. There was a thread here about a month ago of a similar problem, not sure what the fix was but that was mentioned as a possible fix.
Old Feb 25, 2018 | 04:54 PM
navistarnut
Well Hi Jack
you were typing what I was thinking of typing.
Old Feb 25, 2018 | 05:31 PM
packagerjr's Avatar
packagerjr
Doesn't sound exactly like mine but I had a ground in the drivers door harness start breaking in my 07 half ton. Never lost Cluster but would lose power to locks and windows - intermittent at first, then progressing to full loss of function. Something to keep in your back pocket if better leads don't pan out.
Old Feb 25, 2018 | 07:56 PM
DSMMH's Avatar
DSMMH
OP, you might want to “step” your 30 amp relays. By that I mean go to the power panel and take out the top left relay. Take each subsequent one and move it to the vacant slot. Then put the the first one in the last open slot. That should verify it is not a relay problem and if you want to go back, it is easy to do.
Ed
Old Feb 25, 2018 | 08:41 PM
snorindad's Avatar
snorindad
Thanks for the replies. I have not replaced any lights. I will try replacing the fuse and try the relay thing and see what happens. It was only doing it about once a week but in the last two days its gone on and off close to a dozen times.
Old Feb 25, 2018 | 09:35 PM
mattdoc88's Avatar
mattdoc88
Fuse 33 for cluster, 4x4, and wipers is a key one to check. Try replacing it. Wiggle it and see if you hear relays click. The radio, etc, turn on when the cluster says to, it's the same system that keeps them on after you turn off the engine but haven't opened the door yet. It could be a loose socket where the fuse goes, or a bad fuse there .
Old Feb 25, 2018 | 10:53 PM
xcrsp440's Avatar
xcrsp440
Do a search on instrument cluster failures, symptoms sound just like yours.
My sons truck did similar things, had the cluster rebuilt, all is good now.
Old Feb 26, 2018 | 04:35 AM
Yahiko's Avatar
Yahiko
Briam give the people over at https://circuitboardmedics.com
a call. They are also a sponsor. They can give you the steps
to take to pinpoint the issue.
Old Apr 25, 2018 | 09:34 AM
snorindad's Avatar
snorindad
You hit the nail on the head. So I finally just took it in to the dealer and they called me yesterday and said it was the instrument cluster. Its going to cost me 900 parts and labor. I am just glad it is fixed. Thanks for everyone's help.
Old Apr 25, 2018 | 02:22 PM
Yahiko's Avatar
Yahiko
Why have you not given https://circuitboardmedics.com/ a call.
They support FTE and have a much better price than any dealer.
Old Apr 26, 2018 | 02:16 PM
snorindad's Avatar
snorindad
It became a time issue. I wanted it fixed, been working a lot and in the middle of helping my son rebuild his 5.4. Plus normal honey do list. But I do appreciate the info. I have them bookmarked.
Old Apr 26, 2018 | 05:35 PM
Yahiko's Avatar
Yahiko
You might call then and see if they have an exchange program like FICMrepair does.
