Front End Overview
Old Feb 25, 2018 | 03:11 PM
slystatus's Avatar
slystatus
Front End Overview
Hi All,
I am preparing to tear into my 1975 f100 Custom. Amongst other things, I find myself wanting to improve the front end (suspension + steering).
I am investigating options here. I've moved away from the Crown Vic swap as I don't want to lower the thing and that project is a bit ambitious for me anyhow. Although the allure of modern brake and steering was strong.
Any recommendations on suspension parts? I'm nosing around on rock auto and starting to learn about the components in my truck. Suspension in general is new territory for me so beginner level tips and concepts are appreciated.
Old Feb 25, 2018 | 03:34 PM
meangreen92's Avatar
meangreen92
Inspect it with a prybar to check for any undue play anywhere. Inspect all pivot points. Replace any rubber bushings - (are there any?) - and make sure everything is up to snuff.
Then some properly rated quality new springs and good shocks.
Or maybe an air bag system if you're willing to drop the ca$h?
Old Feb 25, 2018 | 06:13 PM
Blue and White's Avatar
Blue and White
The twin I beams worked quite well. Rebuild/replace as needed, get it aligned and you should have a nice setup. See article below.
Getting it to "better than new" specs will take careful evaluation and some work. Maybe king pins. Maybe a good steering gear. Very likely common replacement parts. As far as bushings, OE were rubber. Rubber is OK but quality of replacement parts is variable. Poly bushings are stiffer and more consistent quality IMO.
https://www.hemmings.com/magazine/hm...n/1641228.html
Old Feb 25, 2018 | 07:38 PM
slystatus's Avatar
slystatus
Much appreciated, MeanieGreenie! I'll do exactly that with the prybar. Come to think of it, I have seen something like that done at one tie or another.
Airbag is likely out of my price range at this point but I intend on having the truck for a lifetime.
Old Feb 25, 2018 | 08:26 PM
slystatus's Avatar
slystatus
Thank you, Blue. That link was very helpful. As far as the steering gear, I've seen a lot of clout about redhead steering gears: https://www.redheadsteeringgears.com...2B%24110.00%5D
The price doesn't seem too bad for a highly rated product.
Old Feb 26, 2018 | 01:10 AM
1TonBasecamp's Avatar
1TonBasecamp
Was watching the Truck Tech on TV this morning and they're working on a '75 (I think?) long bed's suspension. Unfortunately on this episode they only got around to the install, but not the re-testing afterwards. Saving that for a later episode.
They did do some track time with the stock-ish suspension though, so should be able to give a good accounting of the improvements.
Nothing major in this case. Just an I-beam lowering kit (3-4 if I remember) and new shocks and anti-swaybars. Next episode tires and such.
Pretty nice truck with a full refresh about 15 years ago. Not planning to do much body work on this one it sounds like, but it'll be fun to watch the suspension progression.
Their supplier for this one was LMC Truck.
(edit: I see someone else started a thread about it earlier)
Paul
Old Feb 26, 2018 | 01:14 AM
1TonBasecamp
Oh, and in addition to the prybar method, you can do a good steering test with a helper racking the steering wheel back and forth while you watch all the components. Not much can match the leverage of the power steering system pushing against the weight of the truck!
With the wheels on the ground and the full weight on them, going through the steering motions will really showcase anything that's loose. With the Early Broncos we use this test to find cracked frames behind the steering gear box. It's about the only thing that will highlight that problem.
But by the same token it really lets you see even tiny bits of play in things like trackbars and radius arms on the 4-wheel drives. I bet it can do almost as much on a 2-wheel truck.
The helper doesn't have to go through the entire range either. Just a quick half-turn one way, then the other, then back again repeatedly will do the job.
With this test you'll find worn bushings, slightly worn tie-rod ends, mis-adjusted wheel bearings and even loose components in the rear suspension too!
Good luck.
Paul
Old Feb 26, 2018 | 08:01 PM
slystatus's Avatar
slystatus
Good luck.
Paul
Hey 1Ton thanks for weighing in...
I just now found a Youtube guide that details the same process for checking steering and suspension, so that's perfect. Can't wait to get visual confirmation and start buying parts!
Furthermore, I should have mentioned earlier that this is a long bed, no power anything with the big six in it. So I was happy to hear about the Truck Tech guys getting work done on a longbed as well.
Thanks again!
Stevaroo01
Jan 1, 2015 11:12 PM
bentobd
Apr 2, 2007 06:34 PM
John Gaquin
Nov 20, 2006 06:37 PM
77' f-100 ranger xlt
Aug 31, 2004 05:02 PM
e william
Jul 2, 2003 01:41 PM
