Leveling Kits: Good or Bad
Old Feb 25, 2018 | 11:22 AM
lasallen's Avatar
lasallen
Will a 2" leveling kit cause premature wear on any parts of the new superdutys. I would love to level my truck, but don't want to be changing parts at 75k miles.
Old Feb 25, 2018 | 11:35 AM
82_F100_300Six's Avatar
82_F100_300Six
Bad. I think they are terrible but my preference reflects 0.000000000001 % of the population. They won't hurt your truck though. But now when you tow you may need airbags or some other kind of junk so you won't be sagging.
Old Feb 25, 2018 | 12:33 PM
CPal's Avatar
CPal
Completely with you. I absolutely hate encountering a leveled truck towing anytime after dark. Headlights always blasting right into my eyes. I also prefer the raked look anyways. To me that's part of what makes a truck look like a truck.
Old Feb 26, 2018 | 03:22 PM
tony m 6.7's Avatar
tony m 6.7
I'm sure that there are many quality leveling kits out there that won't do any damage to your truck. But because I tow frequently I prefer to leave the suspension as it is from the factory with upgraded shocks.
Old Feb 26, 2018 | 03:36 PM
seventyseven250's Avatar
seventyseven250
Lots of people like them, and swear they cause no problems. Some people get them and regret it because of issues. Lots of folks leave things stock and are really happy.
I don't think there's consensus about this topic, just lots of people with strong emotions arguing with each other.
Old Feb 26, 2018 | 03:45 PM
pezracer's Avatar
pezracer
I think I'm going to try stock height with aftermarket 20" wheels on 35s. If no rubbing and it looks good, I might just leave it at that. Leveling seems to be only for looks or larger tire clearance.
Old Feb 26, 2018 | 03:49 PM
Strokin-A-2010's Avatar
Strokin-A-2010
The people who complain about a leveling kit are the ones that didn't have installed correctly.
Old Feb 26, 2018 | 10:32 PM
willynilly's Avatar
willynilly
who doesnt like a saggy truck
Old Feb 26, 2018 | 11:09 PM
tdc_worm's Avatar
tdc_worm
How many ways are there to install a spacer above or below a coil spring?
Old Feb 26, 2018 | 11:23 PM
mikebaby's Avatar
mikebaby
I think they caused excessive wear on my ball joints on my last truck.
Old Feb 27, 2018 | 12:07 AM
Buliwyf's Avatar
Buliwyf
It's bad if you're a lazy hack that the other posters are referring to.
-Set the headlights correctly
-Properly torque the trac bar
-use an adjustable trac bar
-use the alignment bushings
I'm planning to add air bags regardless of level or not. They work great. I want a little more ht up front for a little more wheel travel so I can set my shocks up a little better.
Old Feb 27, 2018 | 05:44 AM
Strokin-A-2010
You would be surprised how people can screw up the easiest things.
Old Feb 27, 2018 | 07:15 AM
Bovinerazzr's Avatar
Bovinerazzr
Same....to me they scream "I don't really need a SD". But hey, when I was 25 I did silly stuff too.
Old Feb 27, 2018 | 07:57 AM
BillyE's Avatar
BillyE
I don't see any reason for them, but to each his own. If you align properly after raising it, then you should be fine.
Old Feb 27, 2018 | 08:09 AM
tdc_worm's Avatar
tdc_worm
I would. Lets assume that I am one of those people and looking for guidance and watchouts. In the spirit of providing guidance, what might a rookie screw up when installing a spacer?
