Leveling Kits: Good or Bad
Old Feb 27, 2018 | 10:51 AM
LadderDogV10's Avatar
LadderDogV10
Has anyone had experience with the rough country 2” kit?
Ive had leveling kits on 2 other SD trucks and never had issues. Trucks were an 04 and 08
Old Feb 27, 2018 | 10:56 AM
falconetti's Avatar
falconetti
Originally Posted by Strokin-A-2010
You would be surprised how people can screw up the easiest things.
I once burned soup.
Old Feb 27, 2018 | 11:12 AM
Paw's 150 Lariat's Avatar
Paw's 150 Lariat
The large and heavy tires sticking out 3 to 4 inches will probably do more damage to the front end components then a leveling kit!!
Old Feb 27, 2018 | 11:53 AM
AMXDREAMER's Avatar
AMXDREAMER
1" (or was it 1 1/2" I can't remember what i put in....lol) level blocks just to take a little rake out of the truck while unloaded and to not create saggy butt when I'm loaded or hauling a trailer. Sort of a "compromise".
Attachment 283980
Old Feb 27, 2018 | 12:42 PM
Tricon's Avatar
Tricon
Originally Posted by tdc_worm
I would. Lets assume that I am one of those people and looking for guidance and watchouts. In the spirit of providing guidance, what might a rookie screw up when installing a spacer?
Its obviously not the spacer, either top or bottom mounted, that causes any issues. Its the track bar, caster cams, brake lines, sway bar drops, bump drops, alignment....do you really not understand this or just being facetious?
Old Feb 27, 2018 | 01:19 PM
willynilly's Avatar
willynilly
does nobody care if the level kits makes your truck sagg down when towing?
Old Feb 27, 2018 | 01:23 PM
Tricon's Avatar
Tricon
They don't. I have an 1,100 lb tongue weight Toy Hauler. My truck is perfectly level when towing. I'd rather have a leveled truck for the 99% of the time I drive it and get air bags if it sagged for the weekends when I tow.
I can't stand that red neck nose dive look. Looks like you're lifting your skirt to the cars behind you. Its all personal preference anyways, complete waste of time arguing the merits of personal preference.
Old Feb 27, 2018 | 01:48 PM
LadderDogV10
The trucks squat in bone stock form as well when towing heavy loads how is that different? When I’ve hauled dual axle trailers with skid steers and AC tractors barn foundation stones it’s sagged every time. Will a leveling kit make it more pronounced? Yes it will it’s a trade off. I personally can’t stand wheels that stick out too far or stacks on diesel trucks or blowing black smoke cause people thing it’s a freight liner. But I don’t loose sleep over it. If your making the payment and it fits your needs so be it.
People get their feelings hurt too easy in this day in age.
Old Feb 27, 2018 | 03:25 PM
ltr's Avatar
ltr
I have put it on my 2016 and 2017 trucks, very simple to put on and have not had any problems with either. Truck still goes straight down the road, steering doesn't seem to be affected, and didn't need the brake line extenders. On my 2017 it felt like the shocks may been topping out or extending to their limit so I used that as an excuse to get some Fox shocks for it.
Old Feb 27, 2018 | 03:29 PM
BillyE's Avatar
BillyE
Originally Posted by falconetti
I once burned soup.
You too? I'd rather file fit rings than cook baked potato soup. I've sworn off the latter.
Old Feb 27, 2018 | 09:02 PM
tdc_worm's Avatar
tdc_worm
not being facetious. given that the majority of level kits do not ship with trac bars, caster cams, brake lines, sway bar drops, or bump drops, i tend to think of a level kit as upper or lower spacers, shock extensions, and maybe track bar drop bracket if you're really swinging for the fences. i figured maybe he knew something that others didnt. those other niceties seem to be more common in full on suspension systems.
as a matter of function, a level kit could potentially get you in trouble if you have a lot of tongue weight while towing. if the rear squats under hard braking, then the front tires become less weighted, negatively impacting braking performance. theoretical? perhaps. certainly more of an issue in 1/2 ton trucks....
Old Feb 27, 2018 | 09:22 PM
Tricon's Avatar
Tricon
I don't think those things are only reserved for full suspension lifts, Carli, Icon, Pure Performance, etc all include them, and while they might not be absolutely required for your truck to function, I bet most of the issues people have with level kits is because they buy the cheapo kits that don't include everything you need to keep the correct geometry. You spend $60-80k on the truck, why cheap out and get a junk $200 kit instead of a real one for $1000. Seems silly to me. If you can't afford to do it right, you're probably not really able to afford the truck in the first place.
I get no squat with an 1100lb tongue weight. Everyone I know that tows anything heavier has airbags (lifted or not) for the increased ride comfort and adjustability. I had them on my half ton, haven't felt the need yet on my SD.
And while I agree, your theoretical scenario sounds plausible, I highly doubt anything like that happens in a real life scenario unless you're way over your payload ratings. Way, way over. At which point 2.5" of rake isn't going to do anything for you anyways. Just my $0.02
Old Feb 27, 2018 | 09:48 PM
  #28
tdc_worm's Avatar
tdc_worm
I hear ya. The OP originally referenced a 2" kit...I took that to imply a spacer kit and not a 2.5" Carli, PP or Icon system. A quick look at Stage3's website (not to imply they are the reference) shows they categorize levels into spacer kits and spring kits. Likely we are in a battle of semantics, but I suspect the OP was referring to a spacer kit, which includes little or none of the niceties of the spring kits. As for they why spend "x" vs "y," if you are going to spend $1k, then why not go full **** and shell out the cash for a Carli Pintop with full leaves and RAs for $6470?
With the tongue weight comment, under normal conditions, probably not an issue. But you do have to ask yourself whey every single pick up truck available comes with a factory rake. I suspect it has to do with protecting/optimizing the handling attitude of the truck under extreme conditions. additionally, the IC of the radius arms raised with a level, resulting in more anti dive and less braking power by the front wheels. maybe it's theoretical, until it isnt, haha. your mileage may vary....
Old Feb 27, 2018 | 10:22 PM
  #29
Tricon's Avatar
Tricon
The $1000 Carli Commuter or Icon Stage 1 kit gives you everything you need to have a safe, reliable, nicely performing lift. Anything above that is for increased performance or more off-road capability. IMO, those are the base level lifts. Anything less than that you are sacrificing one of the above for less money. I don't think risking a crap ride, failed shock mount, brake issues or wobbles and weird steering are worth the few bucks you'd save. So yes, I personally would (and did!) spend quite a bit more than $1000 on a level kit. But if you are just...commuting.... The commuter level kits are the baseline I would shoot for.
I think this has more to do with what the market expects, but yes, the manufacturer needs to make sure the truck handles the rated payload. For $300 you can get air bags and have a better towing ride and still have the look you want while not towing. It's the best of both worlds and cost less than many of the useless OEM add ons.
Old Feb 27, 2018 | 10:47 PM
  #30
willynilly's Avatar
willynilly
this truck must have level kit or smaller rear blocks. with only small trailer and couple atv's it sagging. looks stupid as can be IMO.
