sno fighter verification
Old Feb 24, 2018 | 07:57 AM
F-250 WARHORSE's Avatar
F-250 WARHORSE
Is there an actual sno fighter package decoding? My 1978 has limited slip rear diff, big alternator, 410 gears, dana 60 front/ rear, so that is the lions share of the options, hi output heater!! It might have had dual batteries at one time.
Old Feb 24, 2018 | 10:13 AM
willowbilly3's Avatar
willowbilly3
I special ordered a 76 with the northland special package that had bigger alternator, high out put heater, block heaters and limited slip. So that package might have been included.
Old Feb 24, 2018 | 11:38 AM
Filthy Beast's Avatar
Filthy Beast
I'm not so sure about VIN decoding per se, but I know the BOM on the front axle tube is a dead giveaway for "SnoFighter" package. I think it begins with a 601xx-x or something like that....But it's also for a D60 front (different than the rear) and might not have much to do with decoding this package.
Actually from what paperwork I've accumulated over the years regarding this "package" is that these vehicles so equipped had the F350 suspension package as well as the D60 high pinion front axle.
Offhand, I can't find my paperwork confirming this, but from memory (haha) I think it's pretty close. Hi-output heaters were on HiBoys (from recollection) and weren't necessarily part of the "package."
Mr Bill will probably swing by with better details/confirmation/or abstracts of the SnoFighter moniker.
Old Feb 24, 2018 | 04:56 PM
PA74F250's Avatar
PA74F250
My dads 78 F250 has the high output heater in it, standard alt, dual batteries, D60 front but no clearance lights.
My 79 F250 has standard heater, large alt, 1 battery, D60 front and has clearance lights.
One of us should have a SnoFighter and I believe it's mine. I thought clearance lights had to be part of the equation for them to be.
Old Feb 24, 2018 | 06:09 PM
F-250 WARHORSE
yeah, dual batteries and clearance lights were the package, mine also has a block heater. I really don't know, and the sticker from the door jamb is missing, but thesno fighter package was always referred to on here as (front to rear) dual batteries, HO alternator, d60 front, clearance lights, limited slip rear.
Old Feb 25, 2018 | 09:47 AM
bsyoung1's Avatar
bsyoung1
This may help.it is officially known as the snow plow prep package.
Old Feb 25, 2018 | 10:38 AM
F-250 WARHORSE
Well, I don't know. The wiring is somewhat modified, it has a cluster from an earlier unit, speedo is 100 mph and it is a dummylight cluster, but not oem, has sway bars, has big alt. not sure on clearance lights, have been definetely repainted, drivers door is aftermarket replacement, clearance lights might have been removed. Cool info. Thanks for the post.
Old Feb 25, 2018 | 10:42 AM
JessyJ's Avatar
JessyJ
I have owned 3, 79trucks with the dana 60 front I would think anything with that axel could be considered a sno fighter. Is the sno fighter offered with a dana 44?
Clint40
13
Aug 1, 2024 10:37 PM
DaytonaTunnel
19
Nov 29, 2019 09:15 AM
Towster
Dec 4, 2014 09:55 PM
DaytonaTunnel
Dec 7, 2013 05:51 PM
broncosavage
Sep 14, 2005 08:07 PM
