BCM codes
Old Feb 23, 2018 | 07:48 PM
Martinchris25's Avatar
Martinchris25
BCM codes
does anybody know what scanner I need to access the BCM codes? I have an SCT x4 that I know will read CEL codes but my CEL is not on... any help would be appreciated!
Old Feb 23, 2018 | 08:04 PM
brokenleg's Avatar
brokenleg
A scanner.
Old Feb 23, 2018 | 08:43 PM
Martinchris25
So my tuner won’t work? I’m sure if it won’t then the reader autozone or O’reillys has won’t either?
Old Feb 23, 2018 | 10:13 PM
Olytlr's Avatar
Olytlr
Forscan will work.
Old Feb 24, 2018 | 06:48 PM
Martinchris25
I don’t have FORScan. But I can get an OBD2 adapter. My question is will the FORScan viewer or FORScan lite app for IOS read these BCM codes? I’m not really looking to modify anything right now
Old Feb 27, 2018 | 08:23 PM
jdunk54nl's Avatar
jdunk54nl
Yes. Forscan can read codes as well as a bunch of other bluetooth obd apps.
Old Mar 4, 2018 | 08:22 AM
mueckster's Avatar
mueckster
Forscan works great. I just used it last night to read my TPMS pressures. I was playing around with it some and read some PCM engine parameters, as well. I need to use it more often to be more proficient with it. I have used there extended license to make SCCM changes. It's all pretty easy to do. I recommend getting the "cable version" DLC connector. It has a MS-HS CAN switch and offers faster connection speeds for better communication. This is the one I have and others have used. There is a WIFI version, but I don't have any experience with it. I use the Torque app on my phone; with a Bluetooth dongle. They are fairly cheap and keep one in two of our vehicles.
http://www.amazon.com/OHP-ELMconfig-compatible-interface-diagnostics/dp/B01F0GVBWY/ref=sr_1_1_sspa?s=automotive&ie=UTF8&qid=1520173680&sr=1-1-spons&keywords=forscan+obd2+adapter&psc=1 http://www.amazon.com/OHP-ELMconfig-compatible-interface-diagnostics/dp/B01F0GVBWY/ref=sr_1_1_sspa?s=automotive&ie=UTF8&qid=1520173680&sr=1-1-spons&keywords=forscan+obd2+adapter&psc=1
Deadboy214
Mar 15, 2019 01:33 PM
NinthGenF-SeriesOBS
Mar 24, 2016 04:03 PM
Quick444
Feb 19, 2009 09:58 AM
Iceman31
Apr 21, 2006 10:53 PM
