Adjust electric choke
Old Feb 23, 2018 | 06:39 AM
Ali Zarrin's Avatar
Ali Zarrin
ok here’s the problem, and this makes me wish I had a manual choke. The electric choke makes the truck rev up higher than needed. I’ve gone online and tried to find out how I can fine tune it to work a little better. Right now when the choke is on the truck stays at 20,000 rpm’s which is way too much. I would like it to choke at 15,000. How do I get this done?
Old Feb 23, 2018 | 08:07 AM
Olds64's Avatar
Olds64
Here's a good write up on adjusting an electric choke:
https://forums.holley.com/entry.php?...rel-Carburetor
If you have a Motorcraft 2100 or 2150 the procedurce should be the same. What truck do you own?
BTW, surely you made a typo. The only engine I know of that revs 15k - 20k rpm is a small 2 stroke engine on a weed eater or a chainsaw.
Old Feb 23, 2018 | 09:13 AM
1986F150six's Avatar
1986F150six
I apologize in advance for a brief hijack, but I see the opportunity to share a bit of historical data which might be appreciated by some [I hope so]. And, this might tip off my age... back in 1963, motorcycle manufacturer HONDA made a 2 cylinder 50cc 4 cycle racing motorcycle. It was called the RC114 and produced 14 brake horsepower @ 19,000 rpms. The redline was 20,500 and the engine would tolerate brief bursts to 23,000 rpms. The power band was so narrow that a 9 speed transmission was used.
Old Feb 23, 2018 | 07:34 PM
Franklin2's Avatar
Franklin2
Depends on what carb you have, don't even know the engine you have. But with most, over on the pass side in the choke area there is a fat idle cam, and a adjustable screw to adjust the fast idle rpm.
maples01
18
Nov 19, 2017 01:04 AM
towmater
Jul 27, 2007 12:08 PM
ramtoo
Nov 8, 2005 05:46 PM
HotWhlz85
Nov 4, 2002 02:21 PM
