Changing tire size and fixing it up
Little history on my 02 gold ranger XLT 3.0. Added a few items to the truck, installed a solid receiver, turn signal lights under the ranger logo chrome w/amber leds, put led light under hood for night time, front and rear Led daytime running lights, put brighter dash lights tried using led lights looked grappy, installed a led volt meter just under the dash and put larger alternator from a F150 fit snug, led dome lights nice an bright, Tool box with extra marine battery in it for win I go fishing stays charged and made a bed vinyl cover w/metal backing used lift gate shocks from a bronco to lift the bed cover and put a lockable latch that hooks into the tale gate so neither can be opened. Just trying to fix it up some plan on keeping it for a long time.
Looking to put 265/75R15 tires on any issues with rubbing when turning. Wanted to raise it a little, currently running 235/70R15 on it now. Also looking to change my fuel injectors to 4 hole, any recommendations.
on
Unless you have injector problems this falls under the don't fix what ain't broke category.
Fixing up ranger
Thanks for the advice:
I have a 2wd, would a narrower 265/70R15 be better if I have the right gear ratio I will check tomorrow.
On the fuel injectors, if you accelerate under 300rpm it does fine, but if you kick it between 300-400 it will spit and spudder. If you take off fast or passing gear it does fine. I use fuel injector cleaner pretty much every tank full. Could I have some clogged injectors, if I took them out and cleaned them will it help, injectors are not cheap. Is there a certain type injector cleaner that would work better.
on
The tires you mention running are 3.5" taller and 1.25" wider than what you have now. No way they'll fit a 2wd with out rubbing. And then you suggested a 70 instead of a 75 tire but that will make it an inch shorter not skinnier. Play around with this tire size calculator for a while. https://www.discounttire.com/learn/tire-size-calculator
Example your 235/70/15 tires are 235mm wide, the sidewall height is 70% of that 235mm so sidewall height is 164.5mm x 2 sidewalls = 329mm. Convert that to inches 329/25.4=12.9"+15" wheel diameter equals 27.9" tires. The 265/75/16 you suggested are 31.6" tall.
obars
06-26-2006 10:13 PM
