tailgate damper
Old Feb 21, 2018 | 07:08 PM
coolemoff1's Avatar
coolemoff1
tailgate damper
is the dee zee damper any better ,worse ,or the same as the ford damper add on for half the money
Old Feb 21, 2018 | 07:14 PM
Buxten's Avatar
Buxten
Thumbs up
I ordered my dee zee as soon as I got my truck and haven't had any problems with it yet! Nice gadget for a good price imo,
Old Feb 21, 2018 | 07:37 PM
lariatbob's Avatar
lariatbob
Don't know about the Ford one but the DeeZee one is inexpensive and works great!
Easy to install as well.
Old Feb 21, 2018 | 08:35 PM
Gary E's Avatar
Gary E
I just installed the deezee it’s okay but it’s tight in there and it may rub the paint they even give you a sticker to prevent it, but it just wears through. Plus you will need to remove it before you pull the gate. I kind of wish I would of bought the oem stuff. But I won’t be bothered to change it at this point
Old Feb 21, 2018 | 09:11 PM
grege's Avatar
grege
I had the DeeZee on my F150 for 5 years before this truck. It worked great. Only issue I had was the nutsert getting loose which was probably my fault. I ended up tapping my tailgate and screwing it right in. Also had the plate that mounts on the truck itself fail but DeeZee was quick to send parts to replace the broken ones.
Old Feb 21, 2018 | 09:18 PM
MNSuper's Avatar
MNSuper
One is visible one is not if that matters to you. I had Deezee before on my last truck and loved it. I am a sucker for buying OEM when I can though so I went with the Ford one.
Old Feb 22, 2018 | 05:05 AM
svtride's Avatar
svtride
First thing I did after I rec'd my Lariat was install the Ford OE Damper kit. I like the fact that the damper is hidden within the bed sidewall. Works great.
Instead of using the Taptite (trilobular thread rolling) ball fastener supplied in kit to make the threads in the lower damper attachment point [difficult to get straight access with socket to drive the thread rolling fastener] I tapped the nut-plate first then added Loctite to the ball fastener and screwed it in like a normal bolt. Much easier.
Old Feb 22, 2018 | 07:59 AM
atkinjr's Avatar
atkinjr
I went with the factory OEM dampener also. I read reviews that stated the Deezee can damage your tailgate cable considering they store in the same spot. The factory OEM is hidden in the sidewall
Old Feb 22, 2018 | 08:33 AM
InkMing's Avatar
InkMing
Does the damper come standard on any of the Super Duty trims?
Old Feb 22, 2018 | 08:49 AM
fleming23's Avatar
fleming23
I know my Lariat Ultimate has a soft open tailgate.
Old Feb 22, 2018 | 08:56 AM
user 474747383's Avatar
user 474747383
I use the OEM. DeeZee is just another object to avoid if you use your truck bed, Gravel,Soil, Sand,Mulch,
Old Feb 22, 2018 | 09:01 AM
psdxohio's Avatar
psdxohio
it’s included in the Lariat Ultimate package and standard in the trim levels above Lariat.
Old Feb 22, 2018 | 09:30 AM
atkinjr's Avatar
atkinjr
Part Number: HC3Z-99406A10-A
Tascaparts or wearefordparts are good sources for oem products.
Subtotal:
$60.00
Shipping (UPS - Ground):
$11.86
Total:
$71.86
You would want to pick up some paint and clear coat or send it off to a body shop to match your truck. The part is painted black. I picked up 2 cans from a local auto shop and did it myself.
Old Feb 22, 2018 | 09:34 AM
wingdavid's Avatar
wingdavid
I installed the deezee in my 2008 (steel tailgate with a step ) only change I made was to move the hole for the expanding threaded insert (google it or you tube) I was very pleased with it making a dangerous tailgate drop for my wife to open to very safe.
Now I have an aluminum tailgate without the step, If I do put a damper in it will be the ford OEM one but I am not sure I need it on this truck . Will let my wife decide.
Old Feb 22, 2018 | 10:31 AM
mcr96's Avatar
mcr96
psdxohio , fleming23, This comes standard on the Lariat Ultimate? Can't find anything on the spec sheets that specifies that. Is yours a '18?
