horsepower
Old Sep 15, 2003 | 10:11 PM
fordeverpower's Avatar
fordeverpower
horsepower
I was wondering what you think my engine is making for power. I have a 1971 390 with a edelbrock 600. It is bored .030 over, has open dual exhaust, milled heads, and 2 stepup rv cam. I don't know the cam specs or the stock cam specs. I think it is around is around 325 gross hp. I asked they guy who rebuilt it and he said 370hp. I told him that i thought that was too high. What is your opinon?
Old Sep 16, 2003 | 12:44 AM
Putt's Avatar
Putt
horsepower
If you can get some cam info we can help. You are correct 370hp is way too high for what you listed for your engine. Oh, also need a compression ratio estimate- how much did the heads get milled?
Old Sep 16, 2003 | 09:29 AM
tall69's Avatar
tall69
horsepower
Headers or logs? Headers I assume.
Old Sep 16, 2003 | 11:50 AM
fordeverpower
horsepower
it has manifolds and the usual milling job i guess. I wish I knew more about it but i don't.
Old Sep 16, 2003 | 06:06 PM
Putt's Avatar
Putt
horsepower
Here's an estimate using some assumptions on the unknown specs-210hp @3500rpm and 350 lb-ft of torque @2500rpm.Specs used-9.00:1 cr, mild street cam, stock valves and cyl. heads,stock exhaust. Most Desktop Dyno numbers are about 5% over actual, also must remember these are gross numbers-engine without ps, alt, etc.
Old Sep 16, 2003 | 06:13 PM
Scouder's Avatar
Scouder
horsepower
You really need more info for a reasonable HP guesstimate, but I would say even your 325 number is probably generous. I would put you at 285-300 assuming the following:
Unmodified heads
Factory iron 4bbl manifold
Sea level operation
85 octane fuel
9.5:1 compression
218/218 duration at .050 lift hydraulic cam
Desktop Dyno puts you at 281 HP at 4500rpm
372 Torque at 3000rpm
-Scouder
Old Sep 16, 2003 | 08:41 PM
F100DREAM's Avatar
F100DREAM
horsepower
Here we go for a HP estimate:
1. 390 bored .030 over.
2. Edelbrock performer 4bbl intake
3. Crane 901 (last three numbers from Summit) cam kit, 216 duration at .050, 533 lift., with the crane valve springs that go with the cam.
4. Forge pistons, 10.5:1 compression (have to have 93 octane and can you believe I didn't have to change the rocker arm assembly, left it stock).
5. Hedman headers (3" collector), with 2.5" duals all the way out the back end.
6. Dynomax turbo mufflers.
7. no milling, or valve worked done specially to heads, 68-72 cc flow.
8. Edelbrock 600 cfm, 4 bbl carb (man my truck feels like it wants something more when I get down on it, but maybe that's the 6000 pounds I lug around with the F-100).
9. ARP rods bolts on the crank.
10. Accel electronic distributor, with pertonix ignitor II coil.
11. Melling HV oil pump (I assume this makes no difference, but added anyway).
Thanks a lot.
Old Sep 16, 2003 | 08:43 PM
fordeverpower
horsepower
The factory rating for the1971 390 with the 2bbl was 255hp and 376 tq. I had a cast iron intake and the edelbrock 600 put on. I figured 70 hp from the 4bbl, cam, milled heads, .030 overbore, dual straight pipe. Which i guess to be 325hp gross and 455 tq. With net i think i have 250-260hp and 370tq. Cause gross hp was measured without accessories, with headers, and no air filter. I don't know what else they did. I have ps and alternator for accessories. I have an 4wd automatic with 31 and it seems a bit weak i think. I believe 3.50 gears or so.
Old Sep 17, 2003 | 03:23 PM
Scouder's Avatar
Scouder
horsepower
F100Dream,
I show 393HP at 5000/451TQ at 3500.
I guessed at airflow figures, and assumed a 110lsa on the cam installed at 106.
-Scouder
Old Sep 17, 2003 | 07:39 PM
Gidde Up's Avatar
Gidde Up
horsepower
Still nice!
Old Sep 17, 2003 | 09:58 PM
fordeverpower
horsepower
-Scouder
these gross numbers or net
66crawler
Feb 23, 2012 01:12 PM
46yblock
16
Oct 9, 2006 09:42 PM
RiveraD123
Apr 9, 2004 09:32 AM
bored-68-ford
Feb 7, 2004 03:41 PM
timpage
Mar 25, 2000 10:00 AM
