Power steering hiss
Old Feb 21, 2018 | 02:06 PM
CPal's Avatar
CPal
Mine does same at full lockout. No adaptive steering. I do frequent turn arounds in middle of rural gravel roads and notice it everytime.
Old Feb 21, 2018 | 02:12 PM
Horsehaulin8's Avatar
Horsehaulin8
Mine does it as well. Here's to hoping it's normal. Lol
Old Feb 21, 2018 | 02:29 PM
Pioneer1's Avatar
Pioneer1
Same here. About 2500 miles on truck but just noticed it about 300 miles ago
Old Feb 22, 2018 | 07:34 PM
cdnfireman's Avatar
cdnfireman
The noise you’re hearing is the pressure relief valve built into the power steering system opening at lock to allow the fluid to bypass the steering gear and return to the reservoir. If it wasn’t there the pump would be dead ended and the fluid would overheat and boil inside the pump. Normal sound when you hold the steering wheel hard to either side. Back off the steering a small amount and it will stop.
Old Feb 22, 2018 | 07:43 PM
mrgrayaz's Avatar
mrgrayaz
Noisy noisy. Mine is as well, brand new truck.
Ford has never been able to figure out power steering.....I just curse Ford under my breath and keep going.
My 2005 6.0 was better, it had the Hydro boost brakes...whole different setup :thumbups:
Old Feb 22, 2018 | 08:38 PM
kho6658's Avatar
kho6658
Mine does it also. I had a new 250 for a month, it also did the same. I'm going with normal
trike1946
Mar 15, 2018 08:50 AM
Clover_SD
Dec 4, 2016 05:15 PM
ghunt
Sep 28, 2008 11:53 PM
bremen242
1997 - 2003 F150
Nov 6, 2005 09:32 AM
lm1d
1997 - 2003 F150
Apr 12, 2005 08:55 AM
