Licence plate holder replacement
Old Feb 20, 2018 | 01:57 AM
Big-Red-Lariat's Avatar
Big-Red-Lariat
Any body guys out there? Need to replace my front licence plate holder and surrounding plastic trim (see #17 in pic). Licence plate holder got pushed straight backwards in an accident and bent 2 metal tabs (see blue arrow) on the bumper in behind it.
The new holder and #17 trim both look like they just snap in, so do I need to care about straightening out the 2 metal tabs on the bumper or just leave them bent as they are covered up by the plate?
Old Feb 20, 2018 | 07:18 PM
scott91370's Avatar
scott91370
I can tell you that the tabs will not be noticeable once part #17 is in.
I do think that the tabs on #17 do snap into the tabs though. But I would bet that bending them back would be good enough.
Old Feb 22, 2018 | 05:04 PM
Thorium's Avatar
Thorium
The license plate frame just snaps into the front trim, make sure you get the correct front, you can get the closed or open, the plate frames are not interchangeable from the open type closed front type. The whole front just snaps in and if you slightly crimp the metal clips, save from destroying the front insert, if its not destroyed now. Easy job.
p.s the open front is needed if your truck is boosted, if you have the 5.0, you can have the closed front, thats my understanding.
Old Feb 23, 2018 | 08:15 AM
TJReams's Avatar
TJReams
Starting 2015 all engines use the same license plate holder.
Old Feb 26, 2018 | 11:52 AM
jeffwoodall's Avatar
jeffwoodall
I'm getting ready to order part #17 myself. I have a 2016 and scraped a stupid pole base pulling into a parking spot at a business. Kept easing up a little at a time, barely crawling thinking I would hit the curb any second and BAM, right into the base of the pole. My OCD won't allow me to live with the few minor scratches on the black plastic. What a place to put that pole. I looked at the concrete base and it had been hit probably 200 times. If it had scratched my actual bumper, I would probably have had to post bond by now.
Old Feb 28, 2018 | 10:43 AM
Big-Red-Lariat
OK, so I pulled out the bent metal tabs with vice grips and I thought they were bent back outwards and forward enough, but when I pushed the new $50 plastic trim into the bumper holes, one of the plastic inserts broke. Was too tight I guess. Now the new unit does not sit exactly flush with the bumper at one end only. Not sure how I could have measured it any better, because if it was too far forward, the trim would have fit too loosely.
Trial and error job, 95% successful. I wonder if I heat it up with a heat gun, would it take the form of the bumper in the area of the broken insert, or would this just make a bigger mess?
Old Feb 28, 2018 | 01:49 PM
jeffwoodall
I would call the place you ordered it from and see if they will take a exchange. Perhaps that one tab was weak from shipping it or something, never know. They will probably exchange it if you want to go through the hassle of shipping it back.
Old Mar 2, 2018 | 12:34 PM
sgt_rock's Avatar
sgt_rock
I had to replace one too. My son backed into me in the driveway.
seansolo7144
Appearance & Dress-Up
17
Mar 22, 2020 07:28 PM
347stang
2009 - 2014 F150
Oct 4, 2012 08:37 PM
rlh68050
2009 - 2014 F150
Aug 14, 2010 03:00 PM
propellerhead
Texas Chapter
40
May 18, 2004 04:31 PM
broncobillybob
1978 - 1996 Big Bronco
Feb 29, 2004 12:55 PM
