Glow Plug Module trouble shooting?
Old Feb 20, 2018 | 12:20 AM
agsmv1's Avatar
agsmv1
Talking Glow Plug Module trouble shooting?
Didn't find much anywhere, is there a way to trouble shoot that thing? Having hard starting issues when its chilly. I will troubleshoot the GP's in the AM. Thanks in advance.
Old Feb 20, 2018 | 12:24 AM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
I don't have the 03 book, but I do have the 01 book that talks about troubleshooting the GPCM. You have to get the codes, though. If there is anything wrong with it or the system, it should give you codes.
Old Feb 20, 2018 | 12:27 AM
agsmv1's Avatar
agsmv1
Can I get those off an el cheapo scanner?
Old Feb 20, 2018 | 12:38 AM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
You should be able to, as they come through the PCM and set off the check engine light most of the time.
Old Feb 20, 2018 | 12:45 AM
agsmv1's Avatar
agsmv1
No check engine light, but all the symptoms of something being bad. Had to crank it over several times this afternoon and lots and lots of smoke when it finally started, plus bucking like a wild horse!!
Old Feb 20, 2018 | 12:52 AM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
That sounds like injectors not processing fuel or oil correctly. How many miles on them?
Old Feb 20, 2018 | 12:56 AM
agsmv1's Avatar
agsmv1
Too many! That is next on the plate, just don't have the time right now.
4F right now been sitting for about 5.5hrs and started right up with the remote start..some smoke but nothing abnormal...
Old Feb 20, 2018 | 01:01 AM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
If no codes for the GPCM, then I would suspect injector o-rings or poppet valves sticking. You can shim them for cheap, or replace the external o-rings for cheap. Still the same amount of time as replacing the injectors, though, if you take either approach. Try running synthetic or a thinner oil.
Old Feb 20, 2018 | 01:18 AM
agsmv1's Avatar
agsmv1
Was planning the oil change next week..5w-40 here I come. Thanks for the help and the ideas..You on the night shift to?
Old Feb 20, 2018 | 10:06 AM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
I have been working 2nd shift for 26 years between Navy and PD. Gonna have to learn how to live like a normal person after I retire in a couple of years...
Old Feb 20, 2018 | 02:35 PM
agsmv1's Avatar
agsmv1
I wish we could get a solid shift like that. We rotate days and nights in a 6 week schedule...been doing it 18 years now. Only 20 more to go!!
Old Feb 26, 2018 | 05:11 AM
xxlcajun's Avatar
xxlcajun
4th Gear
Glow Plug Control Module
I just went through the whole glow plug replacement process along with the valve cover gasket assemblies. My 7.3 was slow to crank on chilly mornings like yours but with no more smoke than normal and no bucking like a wild horse.
I did have a wild horse bucking event once and it was the Cam Positioning Sensor. It was still under warranty and the dealer replaced it so I know zero about it. Hope that helps.
Old Feb 26, 2018 | 12:52 PM
agsmv1's Avatar
agsmv1
Hasn't done it since...finally got my Bluetooth adapter and android running on my tablet so I was going to check codes etc this week. Probably Thursday. This damn job keeps getting in my way!!
jetlr1
Oct 3, 2014 02:25 PM
CWO-06250
Sep 25, 2013 06:18 AM
gporonsk
Mar 10, 2012 12:33 PM
rblaine9000
Feb 8, 2011 07:36 PM
