was able to jump the lt blue with orange with blue strip its stay solid allowing it to heat up to see if it flashes
Ok but keep in mind a single bulb might not be enough to cause the flasher to flash, it should but could take a little bit, its possible the flasher is shot.
And, should have asked earlier, are you doing these tests with stock style bulbs or are you using your led bulbs?
Leds might not cause the factory type flasher to function as it should regardless how long you leave it on, i'd have to look it up don't recall off the top of my head but its possible you'd need a solid state flasher for those bulbs.
I just want to say thank you to Danr1 and to Robert Long , the info link was very informative and easy to understand. Danr1 thank you for walking me through the test functions after replacing both flasher units and jumping the corresponding wires i was able to get flashes and signal lights. I plugged back in the multicombination switch and the lights were still not working with the unit after much fiddling around the light blue wire was not making a good connection with its pin , i strip the wire and repinned it with electrical solder. Know that there is a good connection the unit is working fine so thanks for saving me the 75$ and headache of not having to go through the electrical with a comb.
Hey great and thank you, I would also like to say thanks for the update letting us know what was the final fix.
Makes the thread much more useful to others that may find it in the future, knowing what was done to correct the problem rather than yet another an open ended issue, no restitution provided good or bad.
