1969 crew cab question
Old Feb 17, 2018 | 08:44 PM
1KILLERZ's Avatar
1KILLERZ
Did they make a 1969 4x4 crew cab long box?
Old Feb 18, 2018 | 12:12 AM
RichS2659's Avatar
RichS2659
Ford itself did not produce a bump long box 4x4 CC. Converters like Marmon-Herrington and others produced 4x4 conversions of 2wd F-250/350 long box CC's. So if you see one, it is a conversion done by an outside company or a privately done one using the original frame or mounted on to a newer frame.
Old Feb 18, 2018 | 09:57 AM
willowbilly3's Avatar
willowbilly3
There were plenty of 4x4 F250 shortbeds. But the F350 is the long bed and like rich said, the 4x4 would be a conversion. I did own a single cab 69 F350 dually 4x4 that was a Naapco conversion. Big awkward lumbering thing that bump steered so bad, you better keep your thumbs out of the steering wheel if you didn't want them tore off.
Old Feb 18, 2018 | 10:46 AM
1KILLERZ's Avatar
1KILLERZ
Thanks guys.
its a fire department brush fire truck, with a flat bed on it. More than likely the napco conversion as you stated.
Old Feb 18, 2018 | 01:11 PM
willowbilly3
Pretty cool if you can get it bought right.
Old Feb 18, 2018 | 04:57 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by 1KILLERZ
Thanks guys.
1953/78 F350's were only available with 2WD .. If they have 4WD, they're after market conversions (Marmon-Herrington, NAPCO and etc).
1979 was the first year that FoMoCo offered factory installed 4WD in F350's.
1959 was the first year that F100/250's were available with factory installed 4WD
Old Feb 18, 2018 | 06:02 PM
1KILLERZ's Avatar
1KILLERZ
as always, you're the man numberdummy.
Old Feb 18, 2018 | 06:03 PM
1KILLERZ's Avatar
1KILLERZ
I don't know if it makes a difference, but it's an f250.
Old Feb 18, 2018 | 11:15 PM
willowbilly3
I don't think they did a longbed F250 crew cab. So it's not a longbed or it was lengthened or a 4x4 conversion, which I have not seen after Fords 4x4 introduction in 59. But then I do get proven wrong sometimes.
Old Feb 18, 2018 | 11:21 PM
NumberDummy
All 1965/72 factory Crew Cabs were conversions of Regular Cabs and all were Domestic Special Orders, have a 6 digit DSO number.
There are no specific to 1965/72 factory Crew Cab parts listed in the 1964/72 truck parts catalog, because Domestic Special Order parts are not listed.
Even though FoMoCo introduced factory installed 4WD in 1959 F100/250's, Marmon-Herrington, NAPCO and etc. continued to convert trucks to 4WD per customers orders.
If ordered thru Ford dealers, these trucks are all Domestic Special Orders w/the 6 digit DSO
btw: 9/1988 .. The first time I spotted a 1965 Crew, it was parked off the Needles Highway heading towards Mt. Rushmore. I stopped and took pics because I had never seen anything like it before.
Old Feb 19, 2018 | 07:54 AM
1KILLERZ's Avatar
1KILLERZ
That must have been a sight to see. You still got the picture?
Old Feb 19, 2018 | 09:25 AM
NumberDummy
That must have been a sight to see. You still got the pictures?
Of course, but they were taken w/a 35mm camera, so I cannot post them.
Old Feb 19, 2018 | 06:34 PM
RichS2659's Avatar
RichS2659
Here is a 69 ordering brochure for CC's. Notice that it only shows 149" WB 2/4wd F-250's with 6 1/2 ft beds. The F-350 only 2wd has a 165.5" WB with an 8 ft bed. Notice that for 4wd CC's, it was required to have the 44HD 12 bolt front axle. This must have came out in mid 69 as I have found where ND decoded a 4wd 69 CC vin info that had the LD 44 8 bolt axle.
1969 Ford Truck memorabilia / 1969 Ford Special Order Option Newsletter - Ford 6-man Cab (Crewcab) | FORDification Factory Literature Library
Old Feb 20, 2018 | 01:16 PM
TA455HO's Avatar
TA455HO
Lead Gopher
This is not 1969 here, but is 1970.
Not a lot of new info here, but the 1970 Salesmens Facts Book has a little bit of info on the Crew Cabs, too.
Chad
fordlover801
Nov 16, 2016 07:42 PM
belshe92
22
Jun 3, 2016 01:19 AM
TrevorH
Jan 28, 2005 06:59 AM
Boosted 65
21
Jun 7, 2004 08:01 PM
