Fuel Pump Driver Module repacement, need help
Old Feb 17, 2018 | 08:03 PM
ffjump's Avatar
ffjump
I am trying to change out the fuel pump driver module on my 2009 F150 and am having serious problems. If you have changed this out before and have experience, please let me know how. I have located it on the beam directly above the spare tire. Removing the 2 screws is easy, however I can not pull the wire connector plug off the module. It appears that you only need to push down on the plastic leaver at the top above the plug and pull, but it doesn't come apart. I have used channel locks to push it down while trying to pull and that didn't work either. What am I doing wrong?
Please help
Old Feb 18, 2018 | 01:38 PM
P.Bronner's Avatar
P.Bronner
There's probably grit/crud in the socket so the release tab wont push down far enough.
Hughesjr84
Jul 29, 2015 02:28 PM
Piffery1
1997 - 2003 F150
Sep 9, 2013 05:06 PM
Ms FX4
Mar 6, 2012 01:05 PM
otter814
2004 - 2008 F150
Mar 13, 2011 04:46 PM
DANA60
2004 - 2008 F150
Apr 20, 2010 08:48 PM
