Caster bushings
Old Feb 17, 2018 | 07:06 AM
Jeff53's Avatar
Jeff53
Caster bushings
Being that I'm not personally all that well versed in suspensions and steering, would two of these Moog bushings be all I need to have an alignment shop adjust my 04 to 5.5 degrees (or more) of caster? I'm currently slightly over 4 degrees and it's maxed out. It isn't horrible, but it does have a little wander.
https://www.rockauto.com/en/partsearch/?partnum=K80108
Old Feb 17, 2018 | 09:52 AM
pirate4x4_camo's Avatar
pirate4x4_camo
If your balljoints are maxed out then you would want to use a 1.5* wedge between the axle and springs.
However at 4* of caster you likely have another issues causing your wander, 5.5* will help mask it somewhat but you should really find, fix and repair the worn parts causing the wander.
Old Feb 17, 2018 | 10:04 PM
unleashd's Avatar
unleashd
If your alignment shop will do the setup outside of the standard specs, let me know your results. I don't mind coming out to Winchester to have mine adjusted. All the shops that I've talked to here won't agree to do the 5.5* caster adjustment. Mine is at 3* right now and I have some wander.
Shawn MacAnanny
29
Feb 12, 2016 10:46 AM
bigseadaddy
Nov 10, 2010 05:52 PM
pjwoolw
Mar 29, 2009 10:56 AM
shuttlevalve
Aug 18, 2008 10:55 AM
gotdiesel
Aug 6, 2004 12:08 PM
