Sloppy shifter
Old Feb 17, 2018 | 01:37 AM
robstait's Avatar
robstait
Sloppy shifter
Super sloppy shift linkage on my E-100.
Any trick to getting things tightened up?
Old Feb 17, 2018 | 05:30 PM
EmilBarnabas's Avatar
EmilBarnabas
We assume manual transmission.
Under the van, Loosen up the nuts where the long shift rods attach to the transmission levers.
Move the transmission levers to ensure they are in neutral.
Sit in the driver seat and move the shift lever to neutral.
Where the steering column meets the floor, there is a hole where you can insert a 1/4" pin. A #2 screw driver works if it has a thin handle.
Check the transmission control lever, you should not be able to shift out of neutral.
Go under the van and tighten up the two nuts connecting the long rods with the transmission levers.
Remove the 1/4" pin.
See if it is better.
If that does not solve the problem, then parts in the steering column might be worn out.
Old Feb 17, 2018 | 07:54 PM
robstait's Avatar
robstait
Perfect!
I will try it tomorrow.
Thanks for the help!!
I will let you know how it goes
Old Mar 1, 2018 | 09:26 AM
robstait's Avatar
robstait
Sloppy shifter
so after adjusting the linkage as recommended, I see the linkage at the steering column is badly worn. Can I buy this linkage or do I need to have the linkage refurbished? I am talking about the parts at the bottom end of the steering column
Old Mar 1, 2018 | 09:46 AM
yardbird's Avatar
yardbird
You will probably have to take the parts to a machine shop to have the worn holes welded up and drilled back to the correct size. If the linkage gets worn enough the transmission will stay in first when you push the shifter to second gear. When this happens you will have to get out and move the shift linkage to neutral.
To keep this from happening, pull the shifter lever up toward you when shifting out of first, when reaching neutral, push the shifter down to align the 2nd - 3rd linkage, then shift 2nd and 3rd as normal.
Old Mar 1, 2018 | 05:22 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Click on pic twice to enlarge, then use the mouse to move it around.
Old Mar 7, 2018 | 08:07 PM
Trustee's Avatar
Trustee
I have one of "Old Skool's" steering columns. I think it's been in my '67 for about eight years. It's a work of art. Flawless and beautiful, like a museum piece! It has shifted like fresh out of the showroom ever since.
I've thanked you before, Vic, and I'll thank you again!
- Eddie in NY
Old Mar 7, 2018 | 08:19 PM
robstait's Avatar
robstait
So how do I find out about OldSchools steering columns?
Old Mar 13, 2018 | 02:57 PM
Trustee's Avatar
Trustee
Vic, I never got to ask you... I've had your column for nearly a decade now. How do you suggest I care for it? Other than the grease fitting, what and where do you suggest I lubricate the thing? Still works perfectly!
- Eddie, Long Beach NY
Old Dec 20, 2018 | 11:26 PM
Cole Anthony Adcock's Avatar
Cole Anthony Adcock
i think its this company? https://www.ididitinc.com/c-1341770-...umn-shift.html
Old Dec 21, 2018 | 04:20 AM
Trustee's Avatar
Trustee
No, the OldSkool column was an original Ford column rebuilt by Vic in California
Old Dec 21, 2018 | 07:24 AM
Cole Anthony Adcock
Awesome I may need to find his info. My column definitely will need some love in the near future.
Old Dec 21, 2018 | 05:00 PM
EmilBarnabas
Vic (OldSkool) will take your old steering column, refurbish it better than it came from the factory, and can convert it to/from manual or automatic.
vlafountaine -at - socal.rr -dot- com
Old Dec 23, 2018 | 11:56 AM
Cole Anthony Adcock
im in contact with him now. I’ll be planning to ship my column to him soon.
ericconn
May 6, 2013 12:29 PM
RANGER589
Jul 25, 2011 09:36 AM
flathead95hp
Nov 24, 2007 03:36 PM
snowinindiana
May 22, 2003 02:42 PM
rhmitchel
Apr 7, 2003 09:05 AM
