1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
16-285 75 r tires
Old 02-16-2018, 09:26 PM
nmwolfer's Avatar
nmwolfer
nmwolfer is offline
16-285 75 r tires
I was wondering if I could put 16-285-75 R tires on a 1999 Super Duty
Thanks
Old 02-16-2018, 09:37 PM
CampSpringsJohn's Avatar
CampSpringsJohn
CampSpringsJohn is offline
Yes. Many folks here run 285/75R-16 tires on their trucks, with the factory rims. I run E-rated tires with 70psi in the front and 45psi in the rear. I do raise the rear tires up if I'm going to tow or load the bed up. I have a diesel which is about 500lbs heavier in the front than a gas truck. Not knowing what you have, you may run a little less air if yours is a gas truck.
Old 02-16-2018, 09:52 PM
nmwolfer's Avatar
nmwolfer
nmwolfer is offline
Thanks.
My outfit is the 7.3 International power stroke diesel.
Old 02-17-2018, 10:03 AM
irydasteelhorse's Avatar
irydasteelhorse
irydasteelhorse is offline
i run them on mine
6.0 and 7.3 United
07-13-2017 11:07 AM
Scratcha
03-15-2010 12:03 PM
Ace!
12-24-2009 04:07 PM
Softballdad
6.4L Power Stroke Diesel
27
11-08-2009 08:00 PM
Quick Reply: 16-285 75 r tires
