Engine Tranny Swap
Old Feb 16, 2018 | 05:44 PM
76BlueGlow's Avatar
76BlueGlow
Engine Tranny Swap
I have a '61 F-250 4x4 flatbed that I need to do an engine/tranny swap on. The truck sat for 30 or so years and the block is cracked (Montana truck stored outdoors!). The transmission and transfer case appear to be shot as well. Is there a swap from a newer Ford truck that is relatively straight forward? This is going to be a weekend driver so I don't care about mileage. Thanks
Old Feb 17, 2018 | 11:42 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Welcome to FTE
What engine does it have now, 223 I-6 or 292 V8?
Old Feb 17, 2018 | 08:13 PM
User 71024's Avatar
User 71024
Bill, am I correct in assuming they hung the engines in the '61 from the front instead of the side? 'cause if that's the case , nothing is an easy swap without building frame mounts.
Old Feb 18, 2018 | 05:22 PM
NumberDummy
Originally Posted by EricJ
Bill, am I correct in assuming they hung the engines in the '61 from the front instead of the side? 'cause if that's the case, nothing is an easy swap without building frame mounts.
See upper & lower pics from 1957/63 catalog, 1964 is the same.
05ranger
Oct 10, 2006 12:34 PM
padd54
Oct 4, 2004 03:09 PM
zdog
Sep 30, 2003 11:26 AM
66_390 mike
Jul 11, 2001 11:34 PM
