The support under the bed is rusted through, and allowing the front of the bed to drop about 2 1/2". I plan on pulling the bed, and installing a new support. What is the best way to get the bed bolts out?
Sometimes the bolts need to have the heads ground off or drilled etc cause the torx just isnt strong enough.. Dorman sells the kit for supports and bolts....Just did mine..
