1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2005 F250 Bed Bolts
Old 02-16-2018, 08:49 AM
Amish Ford's Avatar
Amish Ford
Amish Ford is offline
2005 F250 Bed Bolts
The support under the bed is rusted through, and allowing the front of the bed to drop about 2 1/2". I plan on pulling the bed, and installing a new support. What is the best way to get the bed bolts out?
Thanks!
Old 02-16-2018, 10:51 AM
99f350sd's Avatar
99f350sd
99f350sd is offline
Sometimes the bolts need to have the heads ground off or drilled etc cause the torx just isnt strong enough.. Dorman sells the kit for supports and bolts....Just did mine..
Old 02-16-2018, 10:54 AM
BioBurner's Avatar
BioBurner
BioBurner is offline
When I swapped beds, I had to cut the heads of with a grinder, and replace the bolts and nuts.
Old 02-18-2018, 03:57 PM
4XBuilder's Avatar
4XBuilder
4XBuilder is offline
Grind em out
Ezalycasaid
08-01-2016 03:45 PM
Epd444
06-05-2011 09:03 PM
tpolley
03-24-2009 02:26 PM
bimmerbill
2004 - 2008 F150
02-07-2006 11:54 AM
fatfenders
01-05-2003 01:54 PM
Quick Reply: 2005 F250 Bed Bolts
