I have a 89 f350 7.5L that I've been having rear brakes issues, finally found that the tabs valve was sticking causeing them to drag. When I bypassed the valve even on jack stands the rear brake barely worked. I put a new valve in and that fixed my original problem but it doesn't stop like it used to.Also the pedal goes almost all the way down before anything starts to happen. I bleed them many times no air. I'm kind of thinking my master cylinder has been on it's way out and now that I don't daily it anymore I get in it and realize it used to stop way better than it does. The only thing in the entire system that is original is the master cylinder. Should I just replace it? Any thoughts? Thanks.
If they're the "self adjusting" type, like mine has. Drive it in reverse and slam on the brakes a few times, they should tighten up on their own.
I experienced the same thing, and an older guy told me to back it up and jack the brakes a few times and they got a lot better immediately.
Yes 5 times. Stopped getting air after 2 times, I don't understand how some people get rid of the RABS valve but when I bypassed it my rear brakes hardly worked at all with the rear on jack stands. Air or not they should have still worked. Right?
I bypassed the RABS valve in my Bronco, and I had to adjust the pushrod out a few turns because I didn't get brakes until the pedal was pretty much on the floor
Maybe adjust out your pushrod a little, see if you get some better braking action higher in the pedal.
I think your first post might be dead on, that master cylinder might just be done.
