Brake light problem
Old Feb 14, 2018 | 07:10 PM
Digmonte's Avatar
Digmonte
Brake light problem
Alright, just starting the hunt for this gremlin, problem is:
no left or right brake light.
yes to the following:
1. 3rd cbl works
2. Tail lights work
3. Both turn signals work
4. Hazards work
what I think I know.
3rd turn signal circuit is separate of rear assembly, but still energized by switch on pedal. This leads me to believe there is a relay energized by this feeding cbl and l/r brake lights , I need to find this relay. Could be a contact problem?
Turn signal interupts brake light signal (bl and ts are same filament)
Brake switch is a 2 pole momentary on. Jumped connecters and heard a relay engage. CBL lit up but not lft and rht.
I have pulled and inspected fuses. Turn signals wouldn't work anyway, same feed. Can't backfeed a short.
Possibility the MFS in the steering column?
Old Mar 4, 2018 | 12:50 PM
Digmonte's Avatar
Digmonte
Problem solved.
Faulty relay in slot B of power distribution box.
Megathomas
Electrical Systems/Wiring
Sep 18, 2018 07:38 PM
bradford237
28
Apr 8, 2013 06:51 PM
brooksa44
Nov 19, 2012 04:51 PM
ivanribic
Jan 11, 2004 09:26 PM
