E4OD overdrive just stopped working.
I was driving but stopped to load some stuff.when I started the truck and got out on the road, my overdrive was kicking in from take-off. I went to shut off th OD and the switch no longer worked. I can shift it manually but don't want to risk more damage. It's not fuses... Already checked. Any sound knowledge would be appreciated.
Sound advice.
thanks, that sounds reasonable. I was also told it could bea ground wire or the OD solenoid. Thank you. Will let you know.
Jstkatt
New Member Introductions
11-02-2017 09:38 AM
