Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
VIN/Code check
Old Feb 13, 2018 | 04:24 PM
blackbearford's Avatar
blackbearford
VIN/Code check
Looking at an 85’ F600 today.. 1FDNF60H8FVA68888
As with every classic Ford door sticker the information doesn’t exactly line up in nice columns. Running 370 2V.. what 5 speed and axle are these? Also, anyone know how much fuel the twin step-tanks hold?
GVWR 24,500
WB TYPE GVW BODY TRANS AXLE
177 F60C GA8 CD U8M
Now I’m going to research the buzzing electric brake booster that stays on as long as battery power was connected.
Old Feb 14, 2018 | 05:23 PM
blackbearford
Pretty sure there was no gauge but I was trying to look at the most critical areas first before I bother the owner to lug it out of a rut this weekend. Gave him the go ahead today so I can look deeper and drive it some. Maybe that’s the ‘standard’ hydraulic brake setup for these trucks? Doing lots of learning. From what I understand it’s the hydroboost motor running. Found some good info on these systems and the ‘scary’ Lucas Girling setup... it’s not nearly as bad as they’re all trying to tell me. Info here if anyone is in need: https://www.heavyequipmentforums.com...t.11472/page-5
Starting to think I’ll own a dump truck soon.. can’t give anyone a good reason why; I just like it.
Old Feb 15, 2018 | 03:39 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
GVWR 24,500
WB TYPE/GVW BODY TRANS AXLE
177 ...F60C ... GA8 ... CD ... U8M
CD = Clark model 285 5 Speed Direct.
U8M:
U8 = Rockwell/Timken model H173 Single Speed Rear Axle / 7.17-1 / 17,500 lbs. Rear Axle Capacity.
M = Ford 7,000 lbs. Capacity Front Axle with Power Steering.
Old Feb 16, 2018 | 12:09 AM
Destroked 450's Avatar
Destroked 450
I've only drove a couple of Fords with 370 2V engines, they where both pretty weak.
BleedWheat
Mar 3, 2018 10:08 PM
89460250
16
Feb 10, 2008 07:43 PM
Shawn7240
Dec 7, 2007 04:14 PM
SickPuppy
May 20, 2007 12:27 PM
adharvey2
Feb 15, 2007 07:19 PM
