Choosing a Trans cooler
Old Feb 14, 2018 | 05:15 PM
F250_'s Avatar
F250_
"Eradicate" is also quite similar to "deracinate" and "extirpate".
Old Feb 14, 2018 | 05:17 PM
Walleye Hunter's Avatar
Walleye Hunter
How does 'evacuate' come into play?
Old Feb 14, 2018 | 08:09 PM
StrokinHer01's Avatar
StrokinHer01
https://m.ebay.com/itm/Transmission-...d=391716327676
https://m.ebay.com/itm/Transmission-...d=292040280810
so out of these which one is better if one is
Old Feb 14, 2018 | 08:33 PM
Colorado350's Avatar
Colorado350
They look identical, only difference is the last digit 3 vs 4... I'd buy the cheaper one.
Old Feb 14, 2018 | 08:52 PM
CousinCarl's Avatar
CousinCarl
RockAuto has the first one (they do look identical but PN is same as RA) for $107
Old Feb 14, 2018 | 11:25 PM
StrokinHer01
You got a link?
Old Feb 14, 2018 | 11:33 PM
StrokinHer01
I found it.. total after shipping is $122 will a 26 row be good enough
Old Feb 15, 2018 | 06:21 AM
AllaboutMPG's Avatar
AllaboutMPG
found this from Mark Kovalsky in a post in 2016 and he knows!!!
2003 and 2004 had a 31 row trans cooler. 2005-2010 had a 26 row cooler. The smaller cooler has internal changes that make it more efficient. We measured the same cooling with both sizes.
26 Row is fine.
Old Feb 15, 2018 | 10:59 AM
brian42's Avatar
brian42
Veteran: Navy
I have the 26-row. Less surface area and more efficient for basically the same cooling as AllaboutMPG said. This leaves more airflow for the rest of the coolers use.
Old Feb 15, 2018 | 02:24 PM
StrokinHer01
Thanks guys. I ordered the 26 for $108 shipped and should be here in a week.. I’m not going to put it in the original coolers place instead I’m going to put it in front of the ac condenser so it get max air flow... when I install it does it have to go through the radiator or can I just be the transmission cooler itself
Old Feb 15, 2018 | 03:06 PM
brian42's Avatar
brian42
Veteran: Navy
I'm not sure what year they started the radiator cooler too but if you have it you should use it.
The 6.0 cooler is much better than the stock one so placement is not a concern. I would recommend putting it in the stock location as air flow/cooling is not an issue. You are already going to have to do some custom lines and routing to use the new cooler. There's no need to add custom mounting to the install also.
Don't forget that the lower mounting tabs are going to have slots instead of holes. I used some fender washers to provide enough surface area for the mounting bolt and a secure mount. Just my .02
Old Feb 15, 2018 | 04:20 PM
StrokinHer01
ok. What’s required to hook up the hoses?
Old Feb 15, 2018 | 04:39 PM
  #28
Colorado350
1/2" hose
3/8 to 1/2" barbs - if you just cut the stock hose.
Quality hose clamps
Old Feb 15, 2018 | 05:32 PM
  #29
Stewart_H's Avatar
Stewart_H
Why in the world would you want to bypass the cooling from the radiator? You're upgrading to a more efficient trans cooler, but now you want to remove an important link in the trans fluid cooling?
Stewart
Old Feb 15, 2018 | 06:15 PM
  #30
StrokinHer01
Stewart
in a prior post someone said it may or may not be going through the rad..
