Forescan DPF Filter % problem
Old Feb 12, 2018 | 12:02 PM
polarisimpala's Avatar
polarisimpala
I did all of the changes to my truck a couple of months ago and all are working great except the DPF Filter %. When I first turned it on it showed 15% then went to 20% then it did a regen and went back to 0% which is where it has been sitting for a couple of months. I am pretty sure the truck has done a couple of regens in that time but it just won't register. Anybody else have this issue.
Old Feb 12, 2018 | 01:58 PM
HRTKD's Avatar
HRTKD
There are a couple of threads on this issue. The thinking is that colder weather is affecting the DPF and nothing is actually wrong.
Old Feb 12, 2018 | 02:35 PM
VoodooRob's Avatar
VoodooRob
^^^^ This. Same thing happened to us, as soon as weather warms up and truck runs at full running temp the gauge starts registering.
Old Feb 12, 2018 | 03:33 PM
polarisimpala
Thanks for the replies, I was hoping that is what was happening. My DEF fluid gauge hasn't moved either for a while.
Old Feb 12, 2018 | 03:48 PM
rajones19's Avatar
rajones19
Same here with both DPF and DEF guages. I read all the threads here, and quit worrying. It took well over 3,000 miles for the DEF gauge to move at all. Probably about 4,500 miles now, and it's down to 74% (according to FORScan Lite). I also monitor DPF% in FORScan Lite, and gets to about 27% before the dashboard DPF% gauge begins reading at all. The dashboard DPF% starts to catch up, but typically I hit 500 miles and a regen starts before it ever catches up completely. It will be interesting to see how this changes if winter ever goes away, or when I have the 5th wheel hitched up.
rogere
Aug 25, 2014 05:58 AM
trekbasso
Feb 27, 2014 02:26 PM
American Air-1
24
Nov 18, 2009 09:13 AM
Reload
Oct 12, 2007 05:24 PM
