Intake Advise
Old Feb 5, 2018 | 08:30 PM
69rangerhiboy's Avatar
69rangerhiboy
Question Intake Advise
Hey Guys,
Need some brain power from you experts.
I am in the process planning an engine build for a 72 F100 4 X 4 that I have found. It has a 360 now but I want to put a small block in it. I have a free 351 C 2 barrel manifold and a $100 351 M engine. Question is can I use it on this engine. Don't know anything about Cleveland engines or ford "M" engines.
As always I value all the knowledge on this forum and I humbly thank you!
Old Feb 5, 2018 | 09:51 PM
fe390pc's Avatar
fe390pc
Well the 351M is a big block and a boat anchor. I would stick with the 360 as it's already there. But that's just my opinion of the 351M.
Old Feb 5, 2018 | 10:46 PM
HIO Silver's Avatar
HIO Silver
An FE is a better foundation for building a torquey engine.
Aftermarket support for the 351m is nary plus your bellhousing will not be compatible so add that to the overall cost. The M is a POS of an engine.
Old Feb 11, 2018 | 10:57 AM
hivoltj's Avatar
hivoltj
351c and 351m are the same engine family but 351m has a taller deck height so the intake won't work without some spacer/adaptors which would negate the free intake
Old Feb 14, 2018 | 05:08 PM
MIKES 68 F100's Avatar
MIKES 68 F100
351m or c would need a different transmission too stick with the FE
Old Feb 14, 2018 | 09:40 PM
RichS2659's Avatar
RichS2659
Wrong-o. 67-72 4x4's used NP-435 4 speeds only which were also used in Dents until replaced by T-18's in 1979. 73 saw C-6's. 351M/400's which used the 429/460 bell housing started in1977 with NP-435's and C-6's. 351C's use the SBF bell housing.
Old Feb 15, 2018 | 07:51 AM
willowbilly3's Avatar
willowbilly3
I've owned plenty of 72 and earlier with the BW transmission and not the NP-425. Ford used both.
kevin316
21
Dec 19, 2024 11:35 PM
Super Econoline
15
Oct 25, 2012 09:35 PM
bigfoot7180
Jul 22, 2011 12:56 AM
Hung Gar
Aug 12, 2003 03:21 PM
Skagit
Apr 21, 2003 08:48 PM
