Sponsored by: Auxito
97 f150 ignition problem?
Old Feb 11, 2018 | 04:45 PM
Riverrado's Avatar
Riverrado
Here's the problem. Truck wouldn't start but all my accessories came on and now they won't shut off... I replaced the ignition cylinder but still the same thing....
Old Feb 11, 2018 | 05:49 PM
Bluegrass 7's Avatar
Bluegrass 7
Surprise! The ignition cylinder is not a switch but the mechanical action between your hand and a switch..
The switch is down the steering column and operated be a rod from the cylinder assembly.
Either the rod or the switch may be faulty.
The switch supplies many circuits and functions.
Obviously it is in the ON position for some reason.
Try again.
Good luck.
Old Feb 11, 2018 | 07:09 PM
Riverrado's Avatar
Riverrado
Try again.
Good luck.
Ok. I'm thinking it's something inside that's messed up because even with the new ignition pulled out, my accessories still stay on.... if I could post video, I'd be able to show you.
Old Feb 11, 2018 | 09:26 PM
Bluegrass 7
The rod has the switch operated, or the switch is broken.
The operated switch provides power to the computer by operating a relay, provides power to the start relay that goes through the transmission selector, provides power for the flasher circuits, lights the dash instrument checkout lamps, provides power to the GEM for it's functions, lights the charge circuit lamp etc..
You description tells this. Don't need a video to see it.
Understand it and look for the cause.
Good luck.
Old Feb 12, 2018 | 11:18 AM
Lime1GT's Avatar
Lime1GT
Try checking your PCM relay to make sure contacts 30 and 87 aren't struck together.
Also check Fuse20-50amp in power distribution box; and Fuse21-15amp in junction box fuse/relay panel.
Old Feb 12, 2018 | 08:16 PM
Riverrado's Avatar
Riverrado
So from everything I've looked up, I'm thinking it's the rod mainly due to the fact that I have no feedback in my key thru the ignition...
Old Feb 13, 2018 | 09:16 PM
Lime1GT's Avatar
Lime1GT
Maybe this will help you out. Never had to change one myself.
https://www.fordf150.net/articles/id...9703-F150.html
Odisvan
26
Nov 19, 2018 09:33 AM
prisoner of gravity
Feb 4, 2011 01:03 AM
robert paul
May 26, 2008 01:41 PM
dcara
Electrical Systems/Wiring
Nov 11, 2007 10:45 PM
ftrain
Aug 13, 2002 10:28 AM
