95 f150 ignition switch
Old Feb 1, 2011 | 11:23 PM
prisoner of gravity's Avatar
prisoner of gravity
ignition switch will not rotate to "off".
"run" is fine and "start" is fine.
what to do?
thanks,
Old Feb 1, 2011 | 11:32 PM
motorhead81's Avatar
motorhead81
did you just change the tumbler or the switch or did this just happen with no recent changes
Old Feb 2, 2011 | 07:19 AM
TexasGuy001's Avatar
TexasGuy001
This could be a worn out ignition lock cylinder, broken actuator rod, or a bound up ignition switch. The switch is located on the bottom of the steering column behind the dash.
Old Feb 2, 2011 | 09:22 PM
prisoner of gravity
thanks...no changes or work done, was working fine and suddenly messed up. I'll disassemble this weekend and try to see what's up.
Old Feb 4, 2011 | 01:03 AM
mmhoward's Avatar
mmhoward
I'd say broken actuator rod too.
I just replaced my steering column to fix mine.
1979 300i6
Aug 26, 2014 08:50 PM
tomsash
1966 - 1977 Early Broncos
Jun 11, 2008 09:59 PM
mep123
Electrical Systems/Wiring
Oct 23, 2003 07:31 PM
RGAZ
Sep 30, 2000 08:32 PM
