Backfire? Transmission issue?
Old Feb 15, 2018 | 03:06 PM
JEFFFAFA's Avatar
JEFFFAFA
Read your plugs. I am assuming you had a new "high flow" dual exhaust put on it. A lot of times this requires a richer pair of jets in the carb. Usually 2 steps richer if headers were installed also. I think you will find your plugs showing a lean mixture. The certain speed is actually a certain RPM I believe. Once you reach that spot the idle circuit has stopped helping. And the power circuit that was helping get to that RPM has stopped working. So the carb was left with only it's cruise circuit. Which I believe is now too lean.
Old Feb 15, 2018 | 07:10 PM
orich's Avatar
orich
2x with Mr Jeff with running lean.
If you have a manual choke pull it out a little an see if it runs any better.
You can do the same but with a warm engine slowly cup your hand over the carb intake air filter as your cutting off the air going in to the carb if it run a higher RPM then it needs lager jets. If the engine bogged or if it loads up with gas. Check timing..
And a person who makes it to King is not from being wrong.
Orich
Old Feb 16, 2018 | 03:59 AM
NashvegasMatt's Avatar
NashvegasMatt
I put on a used set of 92 factory ford fox body short headers, and 2.5” pipe. Not sure if that’s “new high flow” by your definition. Lol. Ok I’m tracking with you above, but wouldn’t this happen at idle under the same RPM situation? I can sit in my driveway and throttle up to around 3k which is were I’d be at 65 mph with no issue. My work schedule hasn’t permitted me to check the plugs yet. Hopefully tomorrow we can sort some of this out.
Old Feb 16, 2018 | 08:39 AM
orich's Avatar
orich
Sitting stopped has no load on the motor what so ever.
Not the same ...
Orich
Old Feb 16, 2018 | 09:49 AM
NashvegasMatt
Not the same ...
Orich
good point
Old Feb 16, 2018 | 10:32 AM
JEFFFAFA's Avatar
JEFFFAFA
Orich
LOL!
Thanks Rich. You made my day.
Old Feb 16, 2018 | 10:37 AM
JEFFFAFA's Avatar
JEFFFAFA
Those headers, dual 2.5" pipes, AND you mentioned "chambered mufflers". I am assuming you meant fl*wmaster or a clone of them. Yepper. That's what I would call a high flow exhaust system.
Old Mar 2, 2018 | 06:52 PM
NashvegasMatt
after inspecting them today I saw most with similar issues and 2 that were unlike any others. 6 of them all showed symptoms of running rich; black with soot but otherwise dry. 1 showed high speed glazing which makes no sense to me. Why only 1? The other one pretty wet with oil which I know is rprobably a ring related issue just due to age. None of them showed leaned out visual symptoms. A lot has changed with the truck/motor/carb since I put these on 2 years ago. I may just buy a new set and run a check in a week or so.
As this relates to the backfire/misfire/whatever it is at higher speeds, the plug with speed glazing makes sense, but only one has this condition? I’ve never checked the timing but sure I can do so. After I get this sorted out we may head there next.
Old Mar 5, 2018 | 06:53 PM
JEFFFAFA's Avatar
JEFFFAFA
Well, I would put a timing light on it. Check the timing to be set right and if the timing mark is steady or jumps around. Then hold it at about 1500 RPM and see if the mark bounces around then. If it does chances are your timing chain is shot.
Old Mar 13, 2018 | 04:49 AM
NashvegasMatt
Wanted to do a few week later follow up. I ended up changing the spark plugs which were questionable at best, the rotor cap, and the dizzy cap. After doing so, I reset my air/fuel dials on the 2150 and have not had the issue reoccur. I did notice on the dizzy cap that I took off that there were very minor burn spots on the plastic from where the spark was obviously not hitting the plug points on the cap but the spark was still going off. Less than 1/8th in off all the way around. Almost looks like at some point the dizzy cap shifted or became loose. Nonetheless I haven’t had an issue so far.
Old Mar 13, 2018 | 07:27 AM
orich's Avatar
orich
Did you go to a colder heat rang that should have fixed the an autolite plug.
Reading through you reply's reminded me of when most teenager owned a Modal A or a Model T.
As those were the days of just clean the old plugs an make sure points & cap timing were close:
Over 60 yrs ago, I read in Hot-Rod Mag it was stated when installing headers you may half to change carb jets 2-3 sizes due to running leaner with less back pressure. .
LiveFrom1977f150
19
Jun 5, 2018 01:12 PM
DIYiT
Aug 22, 2011 12:15 PM
factory594x4
13
Jun 11, 2006 03:13 PM
joelayan
Jul 25, 2005 03:01 AM
Redone
Nov 7, 2003 02:16 PM
