Sponsored by: Auxito
Toe in Specifications & Ranges
Old Feb 9, 2018 | 02:27 PM
Rooster403's Avatar
Rooster403
Fellow Ford owners,
Recently I requested if anyone could provide the front end alignment specifications for my 03 F150 Reg Cab, Flairside 4X4 truck. Now I am only seeking the toe in specs and ranges for my truck as indicated herein. Please chime in if you know where the toe should be set, both driver's side and passenger side. Cheers. Rooster
Old Feb 9, 2018 | 04:33 PM
rsylvstr's Avatar
rsylvstr
Here are my recent results which includes the specs. Or as far as Firestone says they are.
Old Feb 9, 2018 | 10:30 PM
steve(ill)'s Avatar
steve(ill)
I normally measure the overall width behind the tires and in front of the tires. I adjust so the front is 3/16 - 1/4 inch less than the back measurement. Then run the truck for 5000 miles and notice any wear on the tread. FORD will give you a "SPEC" and it covers a range.. Sometimes the MAX or MIN or AVERAGE is the BEST place to be set for minimum wear.
Ken Wolkens
2009 - 2014 F150
Oct 24, 2016 09:21 AM
tbm3fan
May 22, 2013 12:46 AM
dmanshane
22
Apr 17, 2013 03:46 PM
woh1955
1997 - 2003 F150
May 11, 2010 08:18 PM
