Alignment Check
Old Feb 12, 2018 | 12:46 PM
  #31
user 474747383's Avatar
user 474747383
You will need to check it.
Old Feb 19, 2018 | 10:20 AM
  #32
daniel044's Avatar
daniel044
Checking back in on this, I installed my Fox Steering Stabilizer and I have to report it eliminated about 95% of the bumpsteer. Its hardly noticeable anymore. I also bought the correct caster bushing for the left side to eliminate the pull from the crowned roads but have not installed it yet. I am doing a process of elimination and right now the steering stabilizer feels like it made a great improvement.
Old Feb 19, 2018 | 12:18 PM
  #33
K-tung's Avatar
K-tung
That’s awesome. Keep us posted as you go.
Old Jun 10, 2018 | 05:23 PM
  #34
F250 2004 Hoss's Avatar
F250 2004 Hoss
Originally Posted by Snowman 8
Why do you want your caster angle so high?I’m sure I am going to get persecuted for saying this but I think caster angles over 2.5 are too high. Everything I’ve been told and read about DW (and I’ve read a lot about it because my 2011 had the DW for 5 years) says you shouldn’t have to go that high. The higher the caster the more the front tires will wander.
Not quite right on your assumption. Increased Caster will increase the cars desire to steer straight ahead and recenter after going around a turn. The draw back to increased Caster is harder steering. I always used it to fine tune conpensation for road crown. 1/2* more caster on the RH wheel and 1/4* more camber on the LH side.
Old Aug 22, 2019 | 12:20 PM
  #35
FONRDAY's Avatar
FONRDAY
What year is your truck. Looks they have cleaned off oil from a upper oil pan leak.
Old Aug 22, 2019 | 02:43 PM
  #36
Hunt4horns's Avatar
Hunt4horns
That post is over a year old .
Old Aug 22, 2019 | 03:48 PM
  #37
FONRDAY's Avatar
FONRDAY
And the stabilizer is nice looking
frdf250
Mar 14, 2024 06:24 PM
mgoolsby
Feb 24, 2017 08:35 AM
mr78F150
Jun 27, 2015 03:33 PM
jmykec
Feb 17, 2007 02:49 PM
