Route-1 low clearance software
Old Feb 8, 2018 | 03:19 PM
First Dually's Avatar
First Dually
BPofMD...to my knowledge your Garmin RV760 is doing all the routing based on RV data resident on that unit. It is also displaying the low clearance as an icon and likely setting off an alarm. IN ADDITION, the Route1 POI are activating the Garmin RV760 alarm and displaying an associated icon at the POI location.
So, if Route1 has a low clearance POI that the Garmin RV760 does not have built-in, it will alarm and show the associated icon, but will not route around it. This is what I think you observed when you say "Originally Posted by BPofMD
Many times I have turned onto roads that Garmin did NOT have data for that road, but the POI for Route 1 did - and warned me to NOT use this route.".
Old Feb 9, 2018 | 10:47 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
Sounds good to me!! As long as it works...so they say!
Old Feb 9, 2018 | 11:41 PM
First Dually
How many low clearances would you estimate you see displayed via Route1 that you don't see native to the GPS? Can you control how close they need to be to your location before an alarm?
I just ordered a RV GPS and am trying to determine if adding Route1 would be desirable? Your thoughts?
Old Feb 10, 2018 | 05:38 AM
Chuck's First Ford's Avatar
Chuck's First Ford
that being the case....
from GPS dashboard ( or menu )... press detour ahead.. GPS should re-route..
I use the Garmin dezl 770 "Trucker"... 1 1/2 years now. with RV poi factory add-ins.
Old Feb 10, 2018 | 10:14 AM
First Dually
Is it a valid statement that your GPS does not route according to the POI Factory data but it does display and warn for them?
Presumably your doing a re-route is a (rather clever and painless) work-around if you determine the warning is for something that concerns you. True?
Can you select how low a Factory POI obstruction needs to be to display/alarm?
Old Feb 10, 2018 | 11:50 AM
Chuck's First Ford
no, poi factory does not re-route.. but using the gps detour.. will plot a way around...
the Trucker 770 has the size built into it.. and you set your rig size. all 3..
length, width, height.
Old Feb 12, 2018 | 10:25 AM
djousma's Avatar
djousma
I think the confusion about this is surrounding a couple of things.
If your GPS has size data built-in(i.e. RV or Trucker enabled GPS),
- it will never calculate a route with low clearance restrictions for the data built-in to the GPS. However, if you have the low clearance POI's loaded, AND your GPS didn't have a particular low clearance location, your GPS would have calculated that route(wrongly) but you should get the warning for the POI, and should be able to detour around it.
If your GPS does NOT have size data (i.e. standard auto GPS)
- the low clearance POI's will only be proximity warnings. GPS software will NOT route around those. As far as I know, the proximity warnings, are a "circle area", in that you must be within x distance for the POI for the alarm to go off. It doesn't necessarily mean that it will only alarm if it is on the road you are on specifically, but could be the access road next to the highway you are on.
Old Feb 16, 2018 | 08:55 AM
Dan1954's Avatar
Dan1954
While visiting the Ford Sync website I came across a statement that in 2015 Ford began allowing 3rd party info to be loaded into their nav systems. Does anyone have experience with that?
Old Feb 16, 2018 | 09:56 AM
djousma's Avatar
djousma
I just found that article. It was a pre-annoucement for the updated Sync 3, which first became available in Superduty in 2017. The archaic MyFordTouch in the 2016's and older are a no-go. And it appears to be 3rd party apps, I dont know if they allow something like route-1 data to be imported or not.
Thurter
Jan 10, 2021 08:54 AM
michaelschue
Apr 16, 2019 08:37 PM
eazmo
All Things Towing
21
Mar 26, 2018 06:53 AM
ct diesel
All Things Towing
28
Jun 29, 2016 07:07 AM
RV_Tech
All Things Towing
38
Feb 27, 2015 12:54 PM
