Question For 56 Owners
Old Feb 5, 2018 | 04:30 AM
1949f1's Avatar
1949f1
I am putting an emergency brake cable conversion on my 1949 that uses the 1953 thru 1956 cable set up. I am looking for pictures that show where the other end of the cable from the lever under the dash mounts to the bottom of the cab where the cable ends and connects to the rear cables. Thanks
Old Feb 5, 2018 | 08:23 AM
EffieTrucker's Avatar
EffieTrucker
Phantom of the Phorum
I don't have a picture with the cab off and the cable installed on my '53, but I can show you where it goes.
The cable terminates in a crossmember below the cab. Then the threaded cable end sticks through a "U" that equalizes the pull between the two rear brakes.
I hope this helps.
The cable sticks through a hole at "A" and connects to the "U" at "B".
Old Feb 5, 2018 | 10:40 AM
mOROTBREATH's Avatar
mOROTBREATH
I'll get a picture here in a few
Old Feb 5, 2018 | 11:02 AM
56panelford's Avatar
56panelford
The cable from the hand brake lever went through an opening in front of the transmission cover and secured under the cover then to the cross member Effie posted as A
Old Feb 5, 2018 | 12:24 PM
CharlieLed's Avatar
CharlieLed
I use LOKAR cables, much better setup than OEM.
Old Feb 5, 2018 | 09:11 PM
56panelford
I used the same on mine
Old Feb 6, 2018 | 03:29 AM
1949f1's Avatar
1949f1
I hope this helps.
Thanks Effie, This is the picture I have been looking for. After I bought the conversion cable kit I wished I had just put new stock cables back on. I have all the stock connections for doing it but liked this set up better. The 49 does not have this cross member like the 53-56 have. I have an aftermarket steering column so I made a plate to fill the hole up. I know about the front cable running through the hole next to it and how the front stock cable ran so I drilled a new hole straight under the brake handle and ran it over the tranny and I will make something to hold it centered in the frame to hook it to the rear cable. Thank You all for responding about this. Tracy
jeepdad287
Jul 30, 2017 10:36 AM
jfmaz
1983 - 2012 Ranger & B-Series
Jan 18, 2011 03:53 PM
CNC
Apr 25, 2009 08:30 PM
plapczynski
Sep 27, 2008 09:19 PM
1978fordf250
May 14, 2005 11:17 PM
