Fifth wheel prep
Old Feb 4, 2018 | 06:55 AM
sbaluha's Avatar
sbaluha
Fifth wheel prep
I just purchased a 2017 Ford F-250. It has a bed liner. Will I have to modify the bed liner to accept a fifth wheel hitch?
Old Feb 4, 2018 | 07:23 AM
senix's Avatar
senix
You will have to cut the holes in the bedliner so the pucks will be shown. Should be ok otherwise.
Also a cutout for the 7 pin connector will be needed.
Truthfully and spray in liner is better.
Old Feb 4, 2018 | 07:41 AM
Just Strokin's Avatar
Just Strokin
I would go with a spray in liner instead of the plastic. Plastic tends to rub the paint of in places under it and traps water. Granted the aluminum bed is not a problem with rust as was the steel bed.
I ordered my truck with from the factory with the spray in liner and have had no problems with it.
Old Feb 5, 2018 | 08:16 AM
Log Hog Kust'em's Avatar
Log Hog Kust'em
You can cut the bedliner to accept the "rails" for a fithweel hitch and drop the hitch on top of the rails. It may not look as pretty as a spray in liner but it will be harder to dent the bed than with a spray in liner and will save some money by not having to spray in a new liner. Rust is not as big a problem as it was in the '70's. People in the rust belt may disagree.
Old Feb 5, 2018 | 08:37 AM
Just Strokin
There are no rails with the Reese/Ford 5th wheel prep kit. There are 5 holes in the bed for the 5th wheel pucks/goose neck ball to fit into.
Old Feb 5, 2018 | 12:15 PM
sbaluha's Avatar
sbaluha
Thank you for the reply. We got snow last night, so it looks like it may be a bit before i can get to work on it. 20 degrees here.
Steve
rjrandy96
Jun 12, 2019 07:02 PM
zztinker
6.2L V8
Jan 25, 2018 09:20 AM
jinxie
May 14, 2009 10:16 PM
astamp78
Aug 7, 2008 07:33 AM
TJC1989
Dec 8, 2003 06:55 PM
